Koni Shock Absorbers
https://www.ausmini.com/forums/viewtopic.php?f=5&t=2522
Author:  dewey [ Tue Oct 26, 2004 9:48 pm ]
Post subject:  Koni Shock Absorbers
G'day all,
I'm just scoping out Koni shocks and they look like the best option for a bit of performance but not being mega expensive.
What I need to know is... how do you know whether you want std height or lowered height shockies? I will be running 12 x 5's with 165/60/12 rubber so the wheel height should be fairly similar to a 10" rim with std tire profile (whatever it is).
dewey
Author:  drmini in aust [ Tue Oct 26, 2004 10:00 pm ]
Unless you drop it lots, the stockers will be fine.
I'm running stock height Pedders on the hydro and it's reasonably low, 2-3 fingers under guard.. as long as it hits the bump stop before the shock bottoms out you're sweet.
:wink:
Author:  dewey [ Tue Oct 26, 2004 10:08 pm ]
How do you set the height anyway? Isn't it all dependent on where you have your hi-lo's set at? I spose the shockies have a certain range when they're at 'rest' and if you adjust the hi-lo's so that the shocks are outside their specified range then you lose some of the shockie goodness?
dewey
Author:  drmini in aust [ Tue Oct 26, 2004 10:17 pm ]
dewey
Yes you set the height (on dry cars) with Hi-Los if you've got 'em, or cut the trumpets if you don't.
The shockie has a certain travel. Its characteristics are the same for the full stroke. <edit> It is not a spring..
Doesn't matter a rats where it sits, as long as it doesn't bottom out at ends of travel.
All the lowered ones are really just shorter shockies.. 8)
Author:  dewey [ Tue Oct 26, 2004 11:36 pm ]
copy that.
I guess its std height for me then :-D
Author:  ausminis4u [ Wed Oct 27, 2004 9:42 am ]
have you thought of using gaz shocks? i have a set of lowered gaz shocks ready to go on my mini, and they look very well made and are very compeditive on price( i did get these from the uk though.)
Author:  dewey [ Wed Oct 27, 2004 12:28 pm ]
I was under the impression that Gaz are hard to come by in australia?
Are they a bit cheaper than Koni's with similar quality?
Author:  ausminis4u [ Wed Oct 27, 2004 6:29 pm ]
i really duno that one, but they are very good quality for the price.
Author:  drmini in aust [ Wed Oct 27, 2004 8:43 pm ]
Konis= last pretty much forever, then can be rebuilt.
Downside is adjustment- they need to be pushed in and rotated to adjust. Not a dial adjuster like others. But onece set you can forget.
I'd stay away from Spax though, they were crap years ago and still are! :lol:
Author:  Hanra [ Thu Oct 28, 2004 1:23 pm ]
Im runnin SPAX all round, they are lowered shocks, they have 15 adjustments on the which is just done with a flat blade screwdriver on the car. They have been great compared to the Gabriel Red Ryders I had on years ago. The only down side I think is though, is the price!! Pretty sure I paid bout $400 for a pair cupla yrs ago.
Author:  gafmo [ Thu Oct 28, 2004 2:24 pm ]
I'm Staying with the Yellow Koni's
Author:  drmini in aust [ Thu Oct 28, 2004 7:29 pm ]
I had a set on front of a Fiat 124S, couldn't ever get the damping the same on both. Then, they leaked. Agents here were no help- so I flung them and bought Konis.
Recently KC panned them on MM forum- he said quality has now gone well downhill.
If yours are sweet, good luck! :wink:
Author:  Hanra [ Thu Oct 28, 2004 8:16 pm ]
Hmmmm, fingers crossed. Its not the 1st time Ive heard bad things about them.
