Rear storage pockets? https://www.ausmini.com/forums/viewtopic.php?f=5&t=2601 |
Author: | Fat80y [ Mon Nov 01, 2004 12:42 pm ] |
Post subject: | Rear storage pockets? |
Are there any structural problems to consider if I wanted to remove the rear seat pockets? And the rear seat as well for that matter? From what I can see I can just cut them out and the overhanging piece of the rear seat, no strengthening required? |
Author: | minimarc [ Mon Nov 01, 2004 2:13 pm ] |
as far as i know no strengthening issues there unless you mean removing the actual metal seat part or just the cusion ![]() i would think if you remove the whole thing it will be weakend |
Author: | hotbrick74 [ Tue Nov 02, 2004 7:52 am ] |
hello, I think you will find that most people that do it end up putting half alloy/steel roll cages in the back,coz eany bit you cut out is a bit that isnt there doing its thing holding the car in shape if you goto do it,id say get a half alloy roll cage for sure,just to play it safe |
Author: | gafmo [ Tue Nov 02, 2004 8:19 am ] |
How about those Rice brackets that go over your Shocks...Ricers are in thier engine Bay |
Author: | Fat80y [ Tue Nov 02, 2004 8:07 pm ] |
No Probs eh? Good to hear. The reason I ask is I'm in the planning stages of my next mini project. I'm fairly tall at 6'4 and have always found in the past that the driver seat rubs on the pocket, making a nasty hole in the back of the seat. So I figure if I remove the pocket, then I have more room to put different seats in, and possibly further back as well. If you look at the rear seat, under the cushion, there is a piece (of steel) that sits forward (to the front of the car) with a support going down to the exhaust hump in the floor. This is the piece I am also considering removing, as I will be registering it as a 2 seater.... |
Author: | Besser [ Wed Nov 03, 2004 4:24 pm ] |
Post subject: | tortional consideration |
The pocket and seat are part of the tortional rigidity that connects the B pillar to the C pillar. A half cage isnt going to help here much as the std design does a poor job of triangulating front bottom to back top. I remember (6') fitting a deep dish steering wheel and column bracket then reclining the seat (subaru liberty) back. Good Luck |
Author: | kirby [ Fri Apr 23, 2010 4:37 pm ] |
Sorry to bring this up again but what are the options here, has anybody removed the seat pockets and replaced it with something structural but less intrusive? |
Author: | Kennomini [ Fri Apr 23, 2010 6:27 pm ] |
A six point roll cage ![]() Another option is to cut the tops off the bins leaving them level with the seat base (steel). |
Author: | drmini in aust [ Fri Apr 23, 2010 7:19 pm ] |
Another option is to reshape the bins with a BFH (and welder if needed) so they just miss the seats. I did this on my 850 back in the 60s. |
Author: | blue_deluxe [ Fri Apr 23, 2010 11:12 pm ] |
All of the guys in uk have problems at the base of the b pillar, part of it is unsupported if you cut the door bins out. So if you have a welder just put a bit of sheet in there. |
