removing the door pockets...
https://www.ausmini.com/forums/viewtopic.php?f=5&t=2789
Author:  lobby69 [ Thu Nov 11, 2004 8:00 pm ]
Post subject:  removing the door pockets...
hey all again...
i want to make custom door trims for the van,
ive already bought the ply wood n fabric, but i want to remove the door pockets.
is there anything i should know before i take to them with a hack saw???
cheers once again!
blake :shock: :wink: 8)
Author:  Morris 1100 [ Thu Nov 11, 2004 8:05 pm ]
The first thing you should do is swap doors with me!
I have a pair of clubbie doors with the pockets removed and I want doors with pockets.
Author:  Besser [ Fri Nov 12, 2004 9:20 am ]
Post subject:  pocket removal
Try using a drill to drill through the spotwelds half way and then using a chisel (for metal) to hammer it off. On my van I used this method and I had a clean result
Author:  ausminis4u [ Fri Nov 12, 2004 9:56 am ]
how much u want for the doors ?
Author:  rampage101 [ Fri Nov 12, 2004 10:55 am ]
Yeh, easy peasy, just drill the spotwelds away and you good to seperate the metal. I've done it to one of my doors, but I think i'm gonna try and get different doors, mine has already been welded up once before (front corner where the window trim thingy start to go over the wind and back down) and its broke again.
Author:  lobby69 [ Fri Nov 12, 2004 5:30 pm ]
Post subject:  .
cheers all
i just thought there would be significant structural weakness if i were to remove them!
(hey im as stupid as i look!) :wink:
hehehe
cheers,
blake :D :D :D
Author:  lobby69 [ Sat Nov 13, 2004 7:19 pm ]
Post subject:  .
hey,
i made my door trims will put pictures up when i fix the rust behind the drivers door hinge's!
:cry: :cry: :cry:
they look awsum!
im also in the middle of making custom door speaker pods,
i had some trouble locating the spot welds????? :( :(
and the metal chisel just riped a hole in the door....not noticale though!,
so the next best thing was to have some fun with a 100mm angle grinder, got it off nice and quickly with a clean finish!
cheers lads,
blake
