It is currently Fri Jul 18, 2025 9:17 am
 Post subject: 12 Inch Mags
PostPosted: Tue Nov 16, 2004 10:32 pm
Hey All,
I am looking at putting 12inch minilites on my 67 850. I am only running drub brakes at the moment. Will the 12 inch mags fit the standard 850?
Help me out here
Cya
Lucas
PostPosted: Wed Nov 17, 2004 7:59 am
12 inch diamater is no prob, it's the offset you have to be carefull about.
Too much offset and you will need flares, too little offset and the tyres might foul on your rear trailing arm or shock absorber.
PostPosted: Wed Nov 17, 2004 8:44 am
Schweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
Thanx JAM
Lucas
PostPosted: Wed Nov 17, 2004 2:09 pm
Just be carefull with 12's, if you r intending on doing the honda disc brake mod. Make sure the the inside diameter of the wheel is larger than 10in. Ive got a set of 12 by 5 performance superlites which wont fit with a 9in disc, other guys wheels on here do fit though. All because the inside of the rim is only 10in diam.
Users browsing this forum: No registered users and 26 guests
