It is currently Mon Jul 21, 2025 1:31 pm
 Post subject: Gemini Starter issue
PostPosted: Mon Jul 14, 2008 7:11 pm
Hi guys
My starter just ticks once when I turn the key. I can operate the starter with a shifter across the terminals but it will not fire via the key.
I am assuming its the solenoid, is there anything I can service or do I just need to mod another starter motor?
thanks guys
blokeinamoke wrote:
PostPosted: Mon Jul 14, 2008 8:41 pm
Put a screwdriver from the power cable to the spade lug, if it starts you have a wiring issue from your ignition switch.
If not, it's probably the solenoid. These can be replaced without stripping the starter.
PostPosted: Tue Jul 15, 2008 7:57 am
I tried that kev and it still didnt start.
Since its still there could I just put the wire from the spade on the starter back onto the Mini solenoid and then run the heavy cable from the mini solenoid to the other terminal on the starter as per normal mini starter motor?
blokeinamoke wrote:
PostPosted: Tue Jul 15, 2008 8:20 pm
That might spin the starter but it won't engage the pinion. :lol:
Gemini starter is pre-engaged, that means the solenoid first engages the pinion with the ring gear, THEN spins the starter...
PostPosted: Wed Jul 16, 2008 8:12 am
oh crap, will there be anything in there I can fix or should I just go get another solenoid?
blokeinamoke wrote:
PostPosted: Wed Jul 16, 2008 8:20 am
Just go get another Solenoid. They're easy to fit.
Dicko
PostPosted: Wed Jul 16, 2008 4:54 pm
Just a though, would it be possible to rewire it as per original but split the thin wire so that it activates the regular solenoid plus the gemini one?
blokeinamoke wrote:
PostPosted: Wed Jul 16, 2008 5:49 pm
Yes you can do it. But be warned that you then have twice as many things to go wrong.
PostPosted: Sat Jul 19, 2008 1:51 pm
I have tried doing it the way I mentioned and it works ok. The only thing is that the starter stays on until I pull the wire off the solenoid. So I can activate it wth the key, but it will not disengage....
weird huh, I am guessing this is just stemming from what ever the original problem is?
blokeinamoke wrote:
PostPosted: Mon Jul 21, 2008 4:41 pm
Dicko
Or, you could try this...... :wink: :wink:
PostPosted: Mon Jul 21, 2008 6:26 pm
Matt68 wrote:
Dicko
yeah I spose I asked for that didnt eye.
blokeinamoke wrote:
