8 port alloy Weslake style head https://www.ausmini.com/forums/viewtopic.php?f=5&t=40901 |
Page 1 of 4 |
Author: | drmini in aust [ Wed Apr 09, 2008 9:32 am ] |
Post subject: | 8 port alloy Weslake style head |
A Spridget race guy in US has had 10 of these heads cast and machined. I saw one at GR's recently, it is Mini Porn!! ![]() The word was no more would be made, but a thread on MM forum indicates there may be another 10 coming, maybe not.. anyhow... enjoy. ![]() The MM forum thread is here- http://www.minimania.com/web/threadid/9 ... thread.cfm ![]() |
Author: | willy [ Wed Apr 09, 2008 9:55 am ] |
Wow ![]() ![]() What are they worth ![]() |
Author: | spraycanmansam [ Wed Apr 09, 2008 10:05 am ] |
Lots ![]() There was a big discussion on turbominis about them --- http://turbominis.co.uk/forums/index.ph ... tid=186425 |
Author: | mattsmadmini [ Wed Apr 09, 2008 10:36 am ] |
Quote: Works out to be around £950.00 + shipping/taxes
Author: | drmini in aust [ Wed Apr 09, 2008 11:11 am ] |
mattsmadmini wrote: Quote: Works out to be around £950.00 + shipping/taxes ![]() That's not bad, considering an Elder 8 port will cost you near $4K installed and running. Don't forget the Weslake head needs manifolds, valves, springs etc added though, on an Elder they are included. |
Author: | Mini Mad [ Wed Apr 09, 2008 11:19 am ] |
What's better the Elder or the Weslake? |
Author: | drmini in aust [ Wed Apr 09, 2008 11:25 am ] |
Mini Mad wrote: What's better the Elder or the Weslake?
Weslake, GR says. Inlet ports are far better than any other 7 or 8 port. The old iron Weslakes were great back in the 60s, but they used to crack. Ivan Glasby has one of those on his race car. |
Author: | TheMiniMan [ Wed Apr 09, 2008 11:56 am ] |
I ordered 2 of these heads allready & am waiting for the 2nd batch from Rodger ![]() |
Author: | 1018cc [ Wed Apr 09, 2008 12:04 pm ] |
Those are beautiful looking heads! I wish I could afford one. |
Author: | clubmn [ Wed Apr 09, 2008 3:00 pm ] |
Post subject: | mm1275 |
TheMiniMan wrote: I ordered 2 of these heads allready & am waiting for the 2nd batch from Rodger
![]() Man i wish i had the scratch |
Author: | miniimports [ Wed Apr 09, 2008 8:05 pm ] |
Post subject: | 8 port |
doh !!!!!!!!!!!!!!!!!! the secret is out,will have one in the flesh at minishow 2008 at showgrounds for all to see in victoria. i agree with the doc it is pure porn,hope roger does some more (im pretty sure he will) cheers josh |
Author: | Rookiepilot [ Wed Apr 09, 2008 9:48 pm ] |
drmini in aust wrote: Weslake, GR says. Inlet ports are far better than any other 7 or 8 port.
Is this because of the angle of the port directly behind the inlet valve? In the Vizard book he talks about boring holes down through the top of a standard 5 port head which would end up with a similar design. I've heard of this being done with other heads but I've never seen a mini one done, and I can't work out where you could do this on a 5 port, as eveything seems to be in the way. |
Author: | drmini in aust [ Wed Apr 09, 2008 10:46 pm ] |
Rookiepilot wrote: drmini in aust wrote: Weslake, GR says. Inlet ports are far better than any other 7 or 8 port. Is this because of the angle of the port directly behind the inlet valve? In the Vizard book he talks about boring holes down through the top of a standard 5 port head which would end up with a similar design. I've heard of this being done with other heads but I've never seen a mini one done, and I can't work out where you could do this on a 5 port, as eveything seems to be in the way. You need to see the ports in these to appreciate what Graham means. The air entry to the inlet valve throat is magic. And Vizard was just talking about 2 siamesed ports, where this has 4. |
Author: | Mokesta [ Wed Apr 09, 2008 10:54 pm ] |
Inlet port reminds me of the Alfa twin cam. Without valves you can see right through the inlet, chamber and exhaust ports. Very nice indeed. |
Author: | sports850 [ Thu Apr 10, 2008 6:55 am ] |
Rookiepilot wrote: I've heard of this being done with other heads but I've never seen a mini one done, and I can't work out where you could do this on a 5 port, as eveything seems to be in the way.
I've seen that done with varying results on UK cortina's (one looked good but was seriously let down by the guys engineering skills - body steel silastic'ed over the old ports does not make an effective seal ![]() |
Page 1 of 4 | All times are UTC + 10 hours |
