It is currently Fri Jun 20, 2025 11:56 am
PostPosted: Sat Jul 19, 2014 1:28 pm
My apologies if this is in the wrong section of the forum guys :oops:
Couple of unrelated questions, decided it'd be easier than starting two seperate threads.
First of all, my new wheels are here! Well not in my possession, but they landed in Auckland last week and are now on their way to Dunedin. They are Japanese 12x6 SSR Formula Mesh, and are about +12 offset if I remember right. With a 165/60 tyre fitted, can anyone tell me what type of flare would suit them best? I don't want the flares to overhang too much so the smallest size possible would be great, the standard plastic ones ideally, or Wood & Pickett, but if I have to go bigger, obviously I will, just don't want to go out and buy flares only to find i'm still not legal after fitting them, or not being happy with them as they're too big :roll:
Secondly, I've been offered a standard 1100 Clubman motor for a good price, it's condition is unknown as it's been sitting in a car at a wreckers for a few years but as I intend to tickle whatever motor I buy a little bit this isn't an issue, as at the very least a strip down and inspection would be done anyway. Do they offer much more power and torque than a mildly worked 998? By mildly worked I mean a Stage 1 kit (exhaust, filter, carb needle, extractors, inlet manifold), as well as a set of roller rockers and possibly a mild cam. Would these mods on the 1100 offer much more than what the 998 would put out? I've been told 1100s are quite weak, and don't like high revs (not that I intend to build a screamer), is this true? Reason I ask is because 1275s in good nick seem to be very difficult to come by now, my 998 is getting tired and I want something already freshened up that can simply be dropped in in place of it before it does decide it's had enough. If anyone can shed some light on this, I'd be very appreciative, as there doesn't seem to be much information on, or support for, the old 1098 :cry:
I've got 99 problems, and my Mini is all of them.
PostPosted: Sat Jul 19, 2014 7:15 pm
1100s with the right bits can be made go very well they are more torque monsters than powerhouses. the 998 and 1098 share the same bore. but the 1098 has a bigger crank (both are interchangable)
the second mini clubman I owned( in dunedin) had a mild 1098 . i.e cam, head, straight pipe and muffler along with an HS4 carb
i could do a power skid from the octagon tho the lights at moana pool in second gear with ease ( going up hill mind you and dont try that these days, you will get in the poo with the 5-OH!, nor do i condone such behaviour these days)
i say go for it but be prepared for what ever old engine you buy these days good or bad to spend a few grand on a recon
I'd even spend the money if I was deadset on having a dirty nissan RB engine
just my $0.02
PostPosted: Sat Jul 19, 2014 8:15 pm
Yeah recon is definitely on the cards regardless of what I buy.
Why you bring up RB's!? I miss my Skyline :(
PostPosted: Sun Jul 20, 2014 4:29 am
just an example bro nuttin personal
PostPosted: Sun Jul 20, 2014 12:54 pm
Ha yeah i'm just playing with ya :P
So the only difference in the 998 and 1098 is the stroke length (because of crank) and piston height? I take it that means they share the same heads and everything else?
PostPosted: Sun Jul 20, 2014 4:46 pm
yep thats right you could make your 998 into a 1098 by changing the crank
PostPosted: Sun Jul 20, 2014 5:09 pm
and pistons
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jul 20, 2014 5:19 pm
Good to know! I'll probably buy the complete motor, tear down and inspect, then go from there.
That said, my 998's proven bulletproof so far, so I doubt the 1100 would take much to get running or need much work, unless it's been abused...
Sitting in what appears to be an old race car at the moment, one piece front end etc, sorry state though.
PostPosted: Sun Jul 20, 2014 5:26 pm
Scoop wrote:
and pistons
thank you i wondered if was missing something
PostPosted: Sun Jul 20, 2014 5:31 pm
An 1100 will always have an advantage over a 998.
Stock horsepower was 40 for the 998 and 50 for the 1100.
Whatever you do to a 998 will work on an 1100 and you will still be 10 hp in front with the 1100.
PostPosted: Sun Jul 20, 2014 5:37 pm
Sweet! Oh well, time to start firing some emails off I guess :)
Need somewhere to keep the bloody thing too :P
PostPosted: Sun Jul 20, 2014 7:16 pm
Online
An 1100 comes with a better head standard too - a 12G202 compared to a 12A1456 on the 998
Graham Russel did a good three part article on an 1100 engine
http://russellengineering.com.au/projec ... bore-pt-1/
http://russellengineering.com.au/projec ... -bore-pt2/
http://russellengineering.com.au/projec ... -bore-pt3/
Which is also on minimania, which I find easier to read
http://www.minimania.com/Project_Small_Bore__Part_1
http://www.minimania.com/Project_Small_ ... inder_Head
http://www.minimania.com/Project_Small_ ... mbos_Weber
And a couple by Keith Calver
http://www.minimania.com/ENGINE___998_T ... STAGE_ONE_
http://www.minimania.com/Engine___998_T ... er_Options
http://www.minimania.com/ENGINE___1098_ ... ning__1128
PostPosted: Sun Jul 20, 2014 7:37 pm
I'd hold fire on the arches until you have the rims fitted up. I am in a similar situation, but have 10X6's. Everything I had read indicated I would need a wider than standard flare, so had my heart set on the W&P, as I love the idea of hidden screws. However I did a test fit today on the front, but with no engine in place so suspension geometry all screwed up, and it's looking like the standard little flares might be enough.
I'm wondering if the issue is that all the info about likely size is aussie or UK based, and we are allowed to show a little more rubber over here (only tread has to be covered, sidewall can show when looking straight down). Anywho I'd wait.
http://www.mini-hb.co.nz
PostPosted: Mon Jul 21, 2014 12:48 pm
+15 on a 6 inch should fit under group 2 or W&P arches, but hold on until you test fit them. I have +3 in 10x6 and they protrude about 10-12mm.
PostPosted: Mon Jul 21, 2014 4:45 pm
They arrived today :D test fit this weekend hopefully. 10-12mm certainly doesn't sound like much at all, is that from the flat of the guard, the seam or the flare itself?
