What do HIF44 throttle linkage look like?
https://www.ausmini.com/forums/viewtopic.php?f=5&t=4181
Page 1 of 2
Author:  poeee [ Thu Jan 20, 2005 9:01 pm ]
Post subject:  What do HIF44 throttle linkage look like?
What do HIF44 throttle linkage look like? About to buy a manifold and air filter for my HIF44 and was after some pix of the throttle linage, Anyone got some? I'll be searching the UK mini parts sites for pix...
Author:  poeee [ Thu Jan 20, 2005 9:03 pm ]
Ok by the looks of this, it seems to be built in? Correct?
Author:  willy [ Thu Jan 20, 2005 9:05 pm ]
No idea... but how NICE does that look! :shock: 8)
Author:  dr trim [ Thu Jan 20, 2005 9:06 pm ]
bling.
Author:  poeee [ Thu Jan 20, 2005 9:07 pm ]
Nup, I was wrong, thats the choke... needs a linkage... so still after pix!
Author:  brickworx [ Thu Jan 20, 2005 9:11 pm ]
Looks in the picture to have a non adjustable cable....
be careful of hif carbs.... some accelerator cables pull fom underneath and some from on top
Author:  poeee [ Thu Jan 20, 2005 9:47 pm ]
Here is my HIF44. The throttle is to be pulled from the top.
http://www.australianbilliards.com.au/m ... _hif44.jpg
Author:  poeee [ Thu Jan 20, 2005 10:02 pm ]
Many thanks to Zizzle who took some pix for me!
http://www.slabathon.com/~matt/monster_truck/hif44/
Thats exactally what I need for my carbie. Anyone got one? Oh... need an inlet manifold, too!
Author:  simon k [ Fri Jan 21, 2005 7:25 am ]
pooee"http://www.slabathon.com/~matt/monster_truck/hif44/ [/quote]
with that linkage, the cable wraps around underneath the curved part at the front/below the butterfly, and is secured by the bolt thingy with the screw going into it - if that's the carb you're getting, with those linkages (throttle & choke) on it, you don't need anything else
if you get desperate, you can use a single 1 1/5" manifold, just needs to be opened up a bit, only uses 2 of the bolt holes, or you could get a bit of aluminuim and make yourself an adapter plate
Author:  Mini68 [ Fri Jan 21, 2005 7:50 am ]
You will need a throtle bracket as well. This holds the throttle cable, original type airfilter box and is a heat shield. You will also need the part that the outer throttle cable fits into and a carb spacer. You can see all these in the last picture you posted. I got a throttle bracket from Northern Mini Parts. You may need to modify the bracket slightly depending on how thick a carb spacer you can fit.
Kris
Author:  1380 yellow devil [ Fri Jan 21, 2005 8:42 am ]
Looks like you got all the info Me to slow and that looks just like mine but I now have a HF piston and spring instead of the HIF Bearing Dash Pot as it was going up to fast and giving me a flat spot.
Author:  poeee [ Fri Jan 21, 2005 9:46 am ]
You can control that with thicker oil, cant you?
Author:  1380 yellow devil [ Fri Jan 21, 2005 11:57 am ]
yeah but never worked for me as i went up to a 60 grade with no luck.
But I did not try a heavier spring as local supplier did not have one at the time so it got the hs type and stuck that on and all sweet.
Author:  min13k [ Fri Jan 21, 2005 2:40 pm ]
my hif had a little bracket like the one in the picture
makka
Author:  MadMin [ Fri Jan 21, 2005 6:34 pm ]
Still does Makka :D
