TheMiniMan wrote:
If you`d like to do them all with the minimum amount of fluid loss then -->
simply release one bleed nipple (it doesn`t matter which one) then put your foot on the brake pedal & push it to the floor,,, use a piece of broomstick or a section of pipe from your vacum cleaner handle (which is what i use:-) ) & stick it onto the pedal & jam it between the seat crossmember & the pedal to hold it to the floor while you`re doing the job... when done this way no fluid will pass through or leak out at all & you can happilly do all 4 hoses with barely one drop being lost after the initial press to the floor , which you can safely & easilly catch in a hose & bottle as you do it.
easy-peasy
Thanks guys- thats actualy what I was thinking (the holding the pedal down bit) but didn't realise you had to open a nipple first. I thought depress, then open the nipple - catch the squirt and leave the pedal down. I use a hammer jammed between the pedal and the steering wheel mounting bracket when bleeding on my own - its just the right lenght.
