What is the largest over bore suit 1100cc? https://www.ausmini.com/forums/viewtopic.php?f=5&t=47390 |
Page 1 of 2 |
Author: | -=MiniMafia=- [ Sun Nov 09, 2008 12:01 pm ] |
Post subject: | What is the largest over bore suit 1100cc? |
Hey guys, another question re my engine build I am building another small bore, and I wish to stay under 1200cc. Its a shame the use of Hillman Imp pistons takes it to 1215cc. What pistons can I use (mini or non mini) to achieve the maximum cc, but staying under 1200cc. My block is sitting here waiting to go in to get bored/honed, just need to know what to. |
Author: | gerg [ Sun Nov 09, 2008 2:05 pm ] |
I thing GR has 100 thou plus pistons for sale, but I have been know to be wrong. ![]() |
Author: | 1018cc [ Sun Nov 09, 2008 2:33 pm ] |
Based on a quick calculation +0.100" should take a 1098 to 1185cc's. ![]() <edit> I also recall GR having +0.100" pistons for 1098's |
Author: | gafmo [ Sun Nov 09, 2008 2:35 pm ] |
Yep he does but unsure if he has stock? best to call |
Author: | Wombat [ Sun Nov 09, 2008 4:18 pm ] |
+0.100 flat to pistons from GR in my 1098 block ![]() ![]() Just had them done - he should still have them in stock - give him a call |
Author: | Harley [ Sun Nov 09, 2008 5:01 pm ] |
Is it me or has that block got too many holes in the top? |
Author: | -=MiniMafia=- [ Sun Nov 09, 2008 5:19 pm ] |
pure porn. thanks guys. before I call him, how much are they going to set me back? do they come with rings? who makes them? |
Author: | Wombat [ Sun Nov 09, 2008 5:32 pm ] |
I'm sure they come with rings in the price but as to what that is I don't know - they were included in the total price of the assembly. Best ask him. GR has them made to his specs in Tiawan. I had to wait nearly 2 years for them as his first shipment went 'missing' and as by world scale his order was a small one they put the re-run to the bottom of the pile ![]() |
Author: | -=MiniMafia=- [ Sun Nov 09, 2008 5:39 pm ] |
Ah thats no good at all. was hoping to get the motor together for next years meets. Ill give him a call and find out. thanks mate. what compression are you running? |
Author: | drmini in aust [ Sun Nov 09, 2008 5:41 pm ] |
-=MiniMafia=- wrote: pure porn. thanks guys. before I call him, how much are they going to set me back? do they come with rings? who makes them?
I think they are around $275 a set. GR pistons are made in Taiwan, (Hypatecs are too). These come with a Nippon ringset, they are good. Better than Hastings. ![]() |
Author: | Wombat [ Sun Nov 09, 2008 5:41 pm ] |
-=MiniMafia=- wrote: Ah thats no good at all. was hoping to get the motor together for next years meets. Ill give him a call and find out. thanks mate.
what compression are you running? I'm sure he has them in stock - as part of the order went to MS in the UK and needs them for his own stock as well. Haven't worked out compression yet - running 295 head hence the flat tops. |
Author: | -=MiniMafia=- [ Sun Nov 09, 2008 5:47 pm ] |
cheap. ill ring tomorrow to order my set. thanks, once again for everyone's comments. I was planning on using a 940 head, would the flat tops still work with the modifications to the block? |
Author: | drmini in aust [ Sun Nov 09, 2008 9:31 pm ] |
Yes. But your C/R will be pretty high unless you enlarge the chambers heaps, stock they are only 21.4cc. |
Author: | -=MiniMafia=- [ Sun Nov 09, 2008 9:42 pm ] |
hey doc. thats fine, I was after a high c/r, and the head will be quite modified. Ill keep you all posted. |
Author: | -=MiniMafia=- [ Mon Nov 10, 2008 9:19 am ] |
he said I shouldnt be running a 940 head. stick to the 202 instead. He has a lot in stock, so when I get back from my travels ill get the missus to get me some for Christmas. |
