It is currently Sat Jul 19, 2025 5:27 pm
PostPosted: Tue Jan 06, 2009 10:46 am
Hi All!
Im doing some work on the LS and was wondering if there was anyone out there in sydney town a surrounding regions that has an engine stand I could borrow for acouple of months maximum?? I will provide compensation for this kind act in the form of a case of beers
Thanks!
Hi-Ho Silver LS1275
PostPosted: Tue Jan 06, 2009 10:59 am
Go and have a look at supercheap , you can most likely buy one for a smidgen more than the case of beer and then rent it out for alcohol when you're finished .
PostPosted: Tue Jan 06, 2009 11:07 am
I had thought of that but just thought there might be someone who had one lying around not being used, that way we both win the get beer and i dont have even more mini stuff lying around the backyard once im finished! :lol:
Hi-Ho Silver LS1275
PostPosted: Tue Jan 06, 2009 11:08 am
No worries .I've got one here but am a bit too far away .
PostPosted: Wed Jan 28, 2009 8:35 pm
I have an engine hoist but no engine stand if that helps??
PostPosted: Thu Jan 29, 2009 6:24 pm
whereabouts are you?
I have one in Sydney.
PostPosted: Thu Jan 29, 2009 8:35 pm
he lives near the P'matta!
PostPosted: Thu Jan 29, 2009 8:47 pm
OK, I'm not too far away then.
Thanks Em
PostPosted: Fri Feb 06, 2009 9:12 am
hey everyone!
sorry for not replying just got back from holidays
thanks for the offer 1310/71! but i just decided to bite the bullet and just bought one from supercheap
thanks for having my back em, thats why we roll in da same hood' :lol:
Hi-Ho Silver LS1275
PostPosted: Fri Feb 06, 2009 9:37 am
I have a stand, but i cant work out where to mount the engine on the stand... :cry:
Do i need to use the gearbox too?
You can't drive your shares on the weekend...
PostPosted: Fri Feb 06, 2009 10:20 am
You need to make an adaptor to fit an A series to it.
I bolt it to the oil filter pad as well because the generator bracket lugs are not real strong.
I can swing the whole engine and box through 360 degrees.
Here's mine with the 1412 stroker on it-
Note the gearbox shown here is just an empty Mini K case, put on to run it on the engine dyno.
PostPosted: Fri Feb 06, 2009 10:56 am
O.K. I see where I went wrong. I was trying to bolt it on at the traditional spot for a larger motor, on the back where the flywheel would be... :lol:
PostPosted: Fri Feb 06, 2009 11:12 am
The Doc's looks fancy - I just drill extra holes in the plate provided and used some big nuts as spacers where required :wink:
PostPosted: Sun Mar 08, 2009 11:02 am
hey wombat,
was yours the same super cheap one? cause i dont really want to have to make up a bracket cause im only really (hopefully) use it this once, did you bolt it to the actual engine block, or the housing that covers the flywheel?
Hi-Ho Silver LS1275
PostPosted: Sun Mar 08, 2009 8:28 pm
Mine is a Supercrap one - the one with two legs out the front - not the T shaped one. Got it on special for $59 I used the plate that comes with it and drilled extra holes in the right places and attached it to the same points as the Docs on the side but because I didn't reduce the plate down like the Docs I had to use some spacers to line it all up
