Need to borrow engine stand.....will provide case of beers!
https://www.ausmini.com/forums/viewtopic.php?f=5&t=48990
Author:  MiniMe87 [ Tue Jan 06, 2009 10:46 am ]
Post subject:  Need to borrow engine stand.....will provide case of beers!
Hi All!
Im doing some work on the LS and was wondering if there was anyone out there in sydney town a surrounding regions that has an engine stand I could borrow for acouple of months maximum?? I will provide compensation for this kind act in the form of a case of beers
Thanks!
Author:  sports850 [ Tue Jan 06, 2009 10:59 am ]
Go and have a look at supercheap , you can most likely buy one for a smidgen more than the case of beer and then rent it out for alcohol when you're finished .
Author:  MiniMe87 [ Tue Jan 06, 2009 11:07 am ]
I had thought of that but just thought there might be someone who had one lying around not being used, that way we both win the get beer and i dont have even more mini stuff lying around the backyard once im finished! :lol:
Author:  sports850 [ Tue Jan 06, 2009 11:08 am ]
No worries .I've got one here but am a bit too far away .
Author:  man+van [ Wed Jan 28, 2009 8:35 pm ]
I have an engine hoist but no engine stand if that helps??
Author:  1310/71 [ Thu Jan 29, 2009 6:24 pm ]
whereabouts are you?
I have one in Sydney.
Author:  Betty [ Thu Jan 29, 2009 8:35 pm ]
he lives near the P'matta!
Author:  1310/71 [ Thu Jan 29, 2009 8:47 pm ]
OK, I'm not too far away then.
Thanks Em
Author:  MiniMe87 [ Fri Feb 06, 2009 9:12 am ]
hey everyone!
sorry for not replying just got back from holidays
thanks for the offer 1310/71! but i just decided to bite the bullet and just bought one from supercheap
thanks for having my back em, thats why we roll in da same hood' :lol:
Author:  Timinik [ Fri Feb 06, 2009 9:37 am ]
I have a stand, but i cant work out where to mount the engine on the stand... :cry:
Do i need to use the gearbox too?
Author:  drmini in aust [ Fri Feb 06, 2009 10:20 am ]
You need to make an adaptor to fit an A series to it.
I bolt it to the oil filter pad as well because the generator bracket lugs are not real strong.
I can swing the whole engine and box through 360 degrees.
Here's mine with the 1412 stroker on it-
Note the gearbox shown here is just an empty Mini K case, put on to run it on the engine dyno.
Author:  Timinik [ Fri Feb 06, 2009 10:56 am ]
O.K. I see where I went wrong. I was trying to bolt it on at the traditional spot for a larger motor, on the back where the flywheel would be... :lol:
Author:  Wombat [ Fri Feb 06, 2009 11:12 am ]
The Doc's looks fancy - I just drill extra holes in the plate provided and used some big nuts as spacers where required :wink:
Author:  MiniMe87 [ Sun Mar 08, 2009 11:02 am ]
hey wombat,
was yours the same super cheap one? cause i dont really want to have to make up a bracket cause im only really (hopefully) use it this once, did you bolt it to the actual engine block, or the housing that covers the flywheel?
Author:  Wombat [ Sun Mar 08, 2009 8:28 pm ]
Mine is a Supercrap one - the one with two legs out the front - not the T shaped one. Got it on special for $59 I used the plate that comes with it and drilled extra holes in the right places and attached it to the same points as the Docs on the side but because I didn't reduce the plate down like the Docs I had to use some spacers to line it all up
