It is currently Thu Jul 17, 2025 7:30 pm
PostPosted: Tue Nov 11, 2008 12:54 pm
Hi all,
I'm playing around with idea's for repowering my mini.
My current setup is an auto SPi, but I would like to have something that can keep up with today's traffic without having to have the go-pedal jammed to the floor 90% of the time. Basically a mild road mini...
I've thought of keeping my current top end and finding an A+ block and gearbox. I like this idea as I get to keep the engine bay intact with my current wiring loom and aircon etc. It would also pave the way for easy upgrades later on (LCB, roller tips, flowed manifold, K&N filter etc) but I reckon it would be pretty bad from a dosh-to-hp ratio (basically, would cost the same an engine rebuild anyway???). comments?
A specialised 7-port/8-port head is out of the question due to $$$. A Twinky kit sounds nice, but then I would need to chuck the air-con (it is a road mini after all, the missus wouldn't have it). In either case, I would still be stuck with an auto on my current block.
Given this, I'm now leaning to just finding a complete 1275 manual donk (maybe a +0.4/0.6 overbore) and chucking that in. Would probably give a Canems ECU system a try as well, apparently their sequential injection programming gets around the charge robbing normally associated with 5-ports.
Opinons?
PostPosted: Tue Nov 11, 2008 1:22 pm
I dont really know what a auto SPI feels like but i know a 1275 in good order will keep you inline with traffic with easy if u go the few mods you have mentioned
Enjoy Chris ;)
PostPosted: Tue Nov 11, 2008 4:29 pm
auto SPi is feels like - a manual SPi...towing a boat
Also, its getting harder and harder to find someone that can service the things, i'm finding it hard to get a forward clutch for the thing.
So I guess the query is, what's the best (and cheapest) way to get a manual into my car keeping in mind that I probably want to keep EFI.
1. same SPI head, but find an A+ manual block (and probably have to factor costs for rebuilding the engine anyway)
2. Find a good running 1275 complete, and try out the Canems ECU (thinking additional ~$1000 for the ECU would give me a great performing 5 port 1275 - anyone had experience with these yet? http://www.canems.co.uk/).
PostPosted: Tue Nov 11, 2008 5:30 pm
see if Brickworks has any left in his fire sale .......
PostPosted: Tue Nov 11, 2008 7:25 pm
Gee they must be gutless....
Olli is unmodified in any way and undoubtedly has less that his supposed 63hp....but has no trouble at all keeping pace with modern traffic and has been known to give dozy 1970-late 1980's 4cyl autos a fright when he gets off the lights and hits his stride.....
1969 Morris 1100 S Automatic
ahhhh......the interior smell of an old British car....
PostPosted: Tue Nov 11, 2008 9:34 pm
I got new forward clutch plates for a 1275 auto from Allans Motors in Parramatta a year or two ago.
This was an old (Morris 1100S) one, I'm not sure if Rover plates are still the same, but worth a call.
Allan's Motor Engineering
(02) 9683 3793
14 Barney St
North Parramatta NSW 2151
PostPosted: Tue Nov 11, 2008 9:41 pm
Well instead of scrapping the block why don't you convert it to a manual?
I believe that the Mini Man has listed some conversion plates recently... Then just chuck a manual box under it and away you go...
And for bang for your buck for power, I think they say replace the intake and exhaust manifolds, ditch the catalytic converter (if it has one) and regrind the cam. But you only live once so you may as well go all out :D
PostPosted: Tue Nov 11, 2008 11:10 pm
Thanks DrMini, I'll give them a go.
Longer term would be to swap out the auto box...still thinking sourcing a whole complete engine/manual box would be the cheaper option then trying to source a manual A+ block and gearbox (then finding out that the block needs a hone, new pistons...blah blah blah).
albino235, I've heard (from one of DrMini's threads) that the A+ auto block does not easily take to a manual box as the oil galleries are quite difficult to modify.
PostPosted: Tue Nov 11, 2008 11:19 pm
Nah,,, mod to manual is easy
I have the oil pump adaptor plates in stock & then it`s only 3 drillings, (2 for the oil galleries & one for the dip stick hole) mod the oil pressure valve seat (rip it out, block up the 2 extra holes & whack it back in) & you`re done
PostPosted: Wed Nov 12, 2008 5:42 am
Details are in my how-to thread in this mini mods forum-
http://www.ausmini.com/forums/viewtopic.php?t=1461
Note that converting the very late Rover A+ auto ones is more of a problem, details at end of that thread.
PostPosted: Thu Nov 13, 2008 12:19 pm
problem with modding to manual is that you've gotta source a gearbox, and all the manual SPi gear that goes with it (pedal box, different sensors, ECU ???), and rebuild the motor as part of the job. The subframe is different, but that's an easy fix with a spacer block
Josh (aka MiniImports) is doing good prices on SPi manuals, he has one on ebay at the moment for about $3K
PostPosted: Fri Nov 14, 2008 9:00 am
Curious, what is your budget? is it $1000 or $3000? that would help as the suggestiong given here are all on the expensive side (many $1000's).
If you just want more oomph for cheap, perhaps extractors and or a new cam is all you want?
Lillee - 1969 Morris Mini K
PostPosted: Fri Nov 14, 2008 4:31 pm
Budget is about 3.5K but is somewhat flexible. I'm looking for the sweet spot in terms of dollars to HP. ie when its gets to the point where I have to spend 50% of my initial budget to gain 5% more performance, then I would stop. on the other hand, if spending an additional 10% meant a 60% gain in power, then I would really consider it.
Based on the confirmation on the difficulty/cost of adapting an auto A+ to manual, I'm leaning to finding a clean complete 1275 manual motor and adding the Canems ECU injection. Clean, Reliable 100Hp+???
PostPosted: Fri Nov 14, 2008 4:45 pm
Well if you can find a manual motor in good condition and add you ecu, new cam etc. But most engines you find are not in good condition and really need a rebuild. What some people call a 'runner' is really a 'rebuilder'
PostPosted: Sun Nov 16, 2008 8:27 pm
I suggest you look into "bolt on mods" to get you some power, cam, extractors, possibly some head work?
