It is currently Sat Jul 19, 2025 4:57 pm
PostPosted: Mon Mar 09, 2009 9:12 pm
Hi,
Does anyone know if standard Mini flexi hoses from the rear or front end will thread straight into a VH44 booster and seat without problems?
I want to fit a VH44 to the Moke and use flexi hoses, so I can swing the booster up on the guard in the future if it gets in the way of working on the engine. With flexi hoses I wont have to bleed the brakes or worry about dripping fluid on the bodywork.
I don't have any Mini hoses at hand to try, want to check they will fit before I order some.
Alternatively, any suggestions on what flexi hoses others have used with a VH44(Holden, Ford whatever?)
Thanks,
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Mar 09, 2009 10:11 pm
I wouldn't reccommend hoses on a booster, but that said they should fit and seat correctly. I'd use braided hoses, though questions could be raised over the legalities of it. Braided hoses should be a bit better if its going to be moved around, and should have less loss of pedal feel due to expansion.
EDIT: just realised it won't work without installing swivel fittings.
