It is currently Sat Jul 19, 2025 4:56 pm
 Post subject: Oil Filter
PostPosted: Thu Mar 19, 2009 11:50 pm
I use a Valvoline VO 22 - can anyone help me find out the Ryco conversion? :?:
PostPosted: Fri Mar 20, 2009 12:00 am
I'm Bert , where's Ernie
if its a normal spin on one, the ryco one is a z418 :wink:
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Fri Mar 20, 2009 6:04 am
Yep Ryco Z418 is right, is also used on Toyota V6 Camry, V6 Prado and some GM products.
I buy the equivalent Cooper 1035 in bulk, 12 at a time, it's much cheaper. :wink:
PostPosted: Fri Mar 20, 2009 6:59 am
Doc - weren't you using a VW one or something - same top but longer body to give bigger filter area?
PostPosted: Fri Mar 20, 2009 7:25 am
Nope, but I'm aware the early Golfs do fit, as long as you don't have a reverse light switch in a magic wand or remote box. They are longer.
Anyway the Mini Z418 one is big enough, if it'll clean a V6 Camry and GM 5.7L... I add a 25 dia x 10mm rare earth magnet to the outside to grab the fine stuff that goes round.. and round.. and ... :wink:
PostPosted: Fri Mar 20, 2009 9:32 am
Thanks so much!
PostPosted: Fri Mar 20, 2009 11:20 am
PLEASE use any other brand than Ryco for the time being - I know of a few that have disintegrated and ruined engines. Use another brand for a while until they get the diaphragms sorted out.
I'd be using Cooper, AC Delco, even K&N....
Just trying to save some headaches!
PostPosted: Sat Mar 21, 2009 8:48 pm
Tomboss Breweros
The ryco number for the VW size filter is z553, good for catching synchro rings :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Mar 21, 2009 10:07 pm
the ford one fits & is also longer p/# Z62
the mini one is Z82
