Oil Filter https://www.ausmini.com/forums/viewtopic.php?f=5&t=51389 |
Author: | MEllO [ Thu Mar 19, 2009 11:50 pm ] |
Post subject: | Oil Filter |
I use a Valvoline VO 22 - can anyone help me find out the Ryco conversion? ![]() |
Author: | minidrifter [ Fri Mar 20, 2009 12:00 am ] |
if its a normal spin on one, the ryco one is a z418 ![]() |
Author: | drmini in aust [ Fri Mar 20, 2009 6:04 am ] |
Yep Ryco Z418 is right, is also used on Toyota V6 Camry, V6 Prado and some GM products. I buy the equivalent Cooper 1035 in bulk, 12 at a time, it's much cheaper. ![]() |
Author: | Wombat [ Fri Mar 20, 2009 6:59 am ] |
Doc - weren't you using a VW one or something - same top but longer body to give bigger filter area? |
Author: | drmini in aust [ Fri Mar 20, 2009 7:25 am ] |
Wombat wrote: Doc - weren't you using a VW one or something - same top but longer body to give bigger filter area?
Nope, but I'm aware the early Golfs do fit, as long as you don't have a reverse light switch in a magic wand or remote box. They are longer. Anyway the Mini Z418 one is big enough, if it'll clean a V6 Camry and GM 5.7L... I add a 25 dia x 10mm rare earth magnet to the outside to grab the fine stuff that goes round.. and round.. and ... ![]() |
Author: | MEllO [ Fri Mar 20, 2009 9:32 am ] |
Thanks so much! |
Author: | Stuwey [ Fri Mar 20, 2009 11:20 am ] |
PLEASE use any other brand than Ryco for the time being - I know of a few that have disintegrated and ruined engines. Use another brand for a while until they get the diaphragms sorted out. I'd be using Cooper, AC Delco, even K&N.... Just trying to save some headaches! |
Author: | Tombo [ Sat Mar 21, 2009 8:48 pm ] |
The ryco number for the VW size filter is z553, good for catching synchro rings ![]() |
Author: | TheMiniMan [ Sat Mar 21, 2009 10:07 pm ] |
the ford one fits & is also longer p/# Z62 the mini one is Z82 |
