It is currently Sun Jul 20, 2025 4:47 am
PostPosted: Tue Mar 31, 2009 10:15 pm
Hey Guys I am wanting to find out what needle i should be running in my 1380
I have the following specs
1380cc
30/70 cam
ported head with 29/37 valves
9.75:1 compression
K&N Pod Filter
MG Metro Alloy Manifold
Brownrigg Strags with a 2" system
Nissan Electronic Dizzy
A+ Gear box
12inch wheels
Any info will be great. I am usre what spring I have in it but I have been told it should be a yellow one. Mine has not got any paint on it, the needle I have now is a BCE.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Mar 31, 2009 11:09 pm
Your BCE would be a pretty good starting point with the yellow spring
but if you want to ( or rather if it needs) really fueling up, then a BCG adds quite a bit more juice as the revs rise :-)
Proably too much tho but worth a try if your BCE is too lean
depends how well it flows up top really,,, shove the BCE in & yellow spring & give it a whirl,,, then diagnose what`s it`s doing & go from there
PostPosted: Wed Apr 01, 2009 10:07 am
ooh sorry to hi-jack, but how about a 1293 with a HIF44?
thanks! :D
tim
PostPosted: Thu Apr 02, 2009 12:01 pm
Just ordered a yellow spring and I checked what needle I have and it is a RC which is a lot richer all the way then the BCE. Will give this a go and hopefully it will perform a lot better then it does now.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Apr 14, 2009 9:22 pm
I fitted the yellow spring and man does it go now :lol: , A lot more torque and I do not have the flat spot when changing gears. I am really loving driving it again now.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Apr 14, 2009 9:26 pm
thanks! :D
My Dad has a 1310 and he has a red spring and a BDL iand it drive like a dream and has plenty of go the BCE was just to rich for his.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Apr 14, 2009 11:47 pm
excellent news man, yellow makes things richer all the way through & helps push the carb piston back down quicker inbetween gears
Just do a spark plug colour check now tho,,, make sure it`s not "TOO" rich ok???
Otherwise you`ll be wasting fuel & diluting your engine oil with fuel & you`d need to change it way more regularly
cheers for the feedback tho , good on you,,, not enough people come back with the results on here
Users browsing this forum: No registered users and 30 guests
