SU modded for Fuel Injection
https://www.ausmini.com/forums/viewtopic.php?f=5&t=52799
Author:  Blokeinamoke [ Sat May 02, 2009 12:27 pm ]
Post subject:  SU modded for Fuel Injection
Looks interesting
I see no reason why this cant be done for any su all you would need is trigger wheel on the dizzie (pulsar??) and basic fi system.
Author:  TheMiniMan [ Sat May 02, 2009 12:54 pm ]
& throttle possition switch,
Author:  awdmoke [ Sat May 02, 2009 12:58 pm ]
TPS is not required, but you do lose some of the benefits of an EFI system sithout it, i.e. cannot compensate for throttle lag.
Author:  drmini in aust [ Sat May 02, 2009 2:34 pm ]
Why bother with 3 siamese intake ports on that poor Jag, get a 6 port manifold and do it properly! :P
DCOE style injection bodies... :wink:
Author:  Blokeinamoke [ Sat May 02, 2009 2:54 pm ]
they never made any - its easier to use the off the shelf bits
Author:  simon k [ Sun May 03, 2009 11:36 am ]
TPS is easy to add, and use a crank trigger wheel & megasquirt...
not pretty, but I guess it works - a loong time ago I thought about doing similar, but I'd want put the injectors under the carb where the jet is, so you can still have a dashpot and make it look standard-ish - that looks ugly!
Author:  drivinglights [ Fri Jun 05, 2009 2:12 pm ]
Weld weber flanges to a 6-port manifold and fit custom throttle-bods from EFI Hardware in Mitcham. Looks great, no grief, great airflow and comes with a TPS fitting kit.
Author:  Asphalt [ Thu Jun 11, 2009 7:35 am ]
There's a company (I fogott the name) which did exactely that. Standard looking SU carb, but full of electronic goblins and injectors. Looked realy cool. Shame I forgott about the name :(
