CAM 4004 head
https://www.ausmini.com/forums/viewtopic.php?f=5&t=53135
Author:  MG Rocket [ Tue May 12, 2009 12:12 pm ]
Post subject:  CAM 4004 head
I got this ute load mini stuff and among it
is these two heads.
One is a 12G202 and the other is a
smog CAM 4004.
I would like to port one for my MG1100.
But I also have a 1175 block which I will
build at a later date, so which modifies best
for these motors
Author:  drmini in aust [ Tue May 12, 2009 4:12 pm ]
The 12G202 has bigger, better shaped ports to start with so less work to get the same HP.
The CAM4004 will port out OK too, it just takes longer and time is $$$.
Author:  MG Rocket [ Tue May 12, 2009 5:37 pm ]
So the 4004 has more meat in it to remove
but the result is about the same.
Thanks Doc.
Author:  MG Rocket [ Tue May 12, 2009 10:29 pm ]
When porting either of these heads, would I expect to
find the water jacket in the same spot?
Um? I just read that. Er...I really don't want to find
the water jacket, but you know what I mean.
Author:  MG Rocket [ Tue May 19, 2009 5:55 pm ]
I'm still looking at this head.
I measured east/west across the ports
the widest is 67 mm.
Yes they all varied by about 1.5 mm.
My question is this:- Is it possible this head came off a
1275 as the ports seem too wide for a small bore?
This head shows no signs of modification.
Author:  drmini in aust [ Tue May 19, 2009 7:58 pm ]
They are both smallbore heads, won't work properly on a bigbore block.
Where did you measure 67mm??? Head gasket?:?
Author:  MG Rocket [ Tue May 19, 2009 9:51 pm ]
Across the widest part of the chamber on the face of
the head
Author:  drmini in aust [ Tue May 19, 2009 10:12 pm ]
Well on a smallbore 850-998-1098 the chamber overhangs the bore in one direction, and the block in the other (where exhaust valves are).
This is normal.
