It is currently Sat Jul 19, 2025 5:01 pm
PostPosted: Fri May 15, 2009 9:34 pm
Hi, l am new to the forum and have a 62 mini which l am putting a daihatsu k3-ve2 engine on the mini gearbox.l have quaife LSD,sc down gears with big bearing idler.What else would need to be strenghtened in standard rod change box ?Any help much appreciated. :D
mini-62
PostPosted: Sat May 16, 2009 8:54 pm
I've split this off from the 'gearbox power loss' thread, it'll get a bit lost in there... but left it in A series mods because it's an A series gearbox querstion...
what sort of flywheel power do you expect from the daihatsu motor?
PostPosted: Sun May 17, 2009 7:47 pm
Pics please.
Oh and Simon shouldn't this be in "engine conversions" not "A series mods" as it is an engine conversion and not a modification to an A series engine :?: :lol: :lol: :lol:
PostPosted: Sun May 17, 2009 8:26 pm
Kennomini wrote:
Pics please.
:P :roll: :lol:
PostPosted: Sun May 17, 2009 8:32 pm
many mods necessary to make it fit?
PostPosted: Mon May 18, 2009 4:40 pm
Hi,
There is a bit of work to be done on gearbox but will be straight forward to do. Standard Daihatsu engine is 110hp at crank but should make more with better exhaust(no converter) :D
mini-62
PostPosted: Mon May 18, 2009 4:52 pm
speedy... if you stuck with the Sirion gearbox, you could go awd...
http://www.youtube.com/watch?v=ukMzBCD-XYQ
