It is currently Sat Jul 19, 2025 4:22 pm
 Post subject: SC12 Kit Availability
PostPosted: Thu May 28, 2009 11:31 pm
Hi,
Are the SC12 kits still available? How much and from who?
Thanks,
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri May 29, 2009 10:00 am
Ben '92' is the guy to chat to. He's the one that makes the kits up.
User profile - http://www.ausmini.com/forums/profile.p ... file&u=919
Supercharged auto Moke, Brett?? 8)
PostPosted: Fri May 29, 2009 11:32 am
Thanks Poeee.
Yep, that's right, considering supercharging the Moke. Should be fun! :)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri May 29, 2009 11:44 am
Thanks Poeee.
if you're going to corner the toymods market for SC12's, put me on your list ;)
PostPosted: Sun May 31, 2009 8:28 pm
Online
Anybody done a blowthrough setup with an SC12 mounted out the front?
Like this Bini one...
http://www.minimania.com/MsgImages/thum ... B15240.jpg
Could fit an intercooler then too...??
PostPosted: Sun May 31, 2009 10:10 pm
that would be a seriously low mounted alternator!?
PostPosted: Sun May 31, 2009 10:17 pm
This space for rent
Or a seriously high mounted one, where the SC would otherwise go ;)
PostPosted: Sun May 31, 2009 10:31 pm
they'd mount it very low - same spot as where they put the alternator on rovers with a/c
PostPosted: Mon Jun 01, 2009 6:25 pm
I'm planning on mounting my SC14 in that area with a FMIC. Haven't decided on fueling yet but in the long run a blow through may be easier and safer (no air fuel mix in the FMIC).
PostPosted: Mon Jun 01, 2009 9:08 pm
This space for rent
Whoa, you can't set it up with the FMIC after the carb, one backfire and B-O-O-M..
PostPosted: Mon Jun 01, 2009 10:08 pm
Way ahead of ya their :wink:
I'll clarify, if I go FMIC I will use a blow through setup other wise no FMIC.
