It is currently Fri Jul 18, 2025 5:53 pm
 Post subject: Chain drive gearbox
PostPosted: Sun Jul 19, 2009 5:56 pm
Ok so who knows what? I've heard about it a few times but I can't rember any details so fire away. What ratios would be good or size of "cogs" etc etc
PostPosted: Sun Jul 19, 2009 9:55 pm
Austin 1800 Automatics had a "morse" chain drive from crank to box :-)
Maybe start there
& i`d stick with 1:1 as per std issue for now
PostPosted: Mon Jul 20, 2009 6:00 pm
Also what are the disadvantages of this?
I assume their would be a little bit more power available but how much, if any?
PostPosted: Mon Jul 20, 2009 6:40 pm
No fubard idler gears & casings I suspect :)
http://www.mk1-performance-conversions. ... l_dept.htm
Chain drive sounds interesting, was thinking about it myself...
PostPosted: Mon Jul 20, 2009 7:40 pm
That chain pictured is a Hy-Vo chain. As Matt says, the Austin 1800 automatics used one. My mate was always putting new chains in his, and he was not impressed... :x
PostPosted: Mon Jul 20, 2009 8:21 pm
I got a mate who races warick he has got some other motor grafted onto a mini box chain driven as far as I no he hasn't had a prob with it been like it for 20 years o
PostPosted: Mon Jul 20, 2009 8:31 pm
Speaking of stretching chains...
Who can tell me what is going on here?
Kinda looks like something Matt would stick in a buggy. :lol:
PostPosted: Mon Jul 20, 2009 9:18 pm
Hee hee,,, dam right Morry,,,, But (if i`m not mistaken) it looks particularly similar to the "Attempt" that Leyland Australia had in fitting a P76 V8 into the old Land crab via a ZF transaxle assy
Mega bucks the factory spent that ended up going no-where (again)
PostPosted: Mon Jul 20, 2009 9:35 pm
Olds Toronado? It was a V8 FWD.
[edit] or not... - similar but not the same!
1958 Morris Minor 1000 - "Nigel"
PostPosted: Mon Jul 20, 2009 9:45 pm
Back on topic can you try and find out some info about the chain/gears and where he got them?
PostPosted: Mon Jul 20, 2009 11:21 pm
For chains see Chain and Accessories ,C&A Pty Ltd, torrens road Sth Aust. website . They have a lot of info and tables for HP calcs to compare for different types of chains, with sprocket sizes
www.minisprintgt.com
PostPosted: Tue Jul 21, 2009 11:04 am
he made it all up himself - Warwick Agustin - he's in the NSW Super Mini series with a toyota 4AGE on a mini gearbox.
He told me once that in the early days he had problems with rings cracking, he tracked it down to the chain hitting on some alloy casting, shaving the alloy which got into the oil, then cooked itself onto the bores, then when the rings went past - crunch
PostPosted: Tue Jul 21, 2009 3:35 pm
send me a PM aaaaaaaand i will send you Warwicks contqct details, it is a interesting job that does cause a few problems like he says that because of all the mass of the chain and sprokets he cant change gears as fast as normal
