Harley and sgc:
yep, fiber glass mini shaker bonnet, painted gold on the green car.
blue deluxe & spraycanmansam:
I'm not sure if it drops the power band down that much. The race car i'm building at the moment (Formula SAE, not a mini) has tuned runners to 5000rpm which are slightly shorter these ones will be, with the length of these ones it wont have a huge effect on the power curve (i think) its more about torque. At the moment my peak power is about 5500 rpm anyway, i usually don't use that and wouldn't mind it having a bit more grunt lower down. Yes should increse torque which will be very nice in the engine i'm running now
Mokesta
cant really do much about the fuel wanting to go towards the outside of the manifold, apart from getting as fine a spray as possible. and as you say keeping it warm. If it is bad i'll run two channels along the outside curve and water heat it. cold on the inside of the curve, hot on the outside... do you think that would work well enough? very impressive manifold by the way, how come you ran dual injectors?
Flute:
i have the big K&N filter already (2"?) and a 5" manifold thats been ported and gas flowed, which wont fit, but i also have some of the smaller filters and a shorter manifold (but would still need to move my speedo). Just having a little fun!
