Cam question very noob!
https://www.ausmini.com/forums/viewtopic.php?f=5&t=55673
Author:  mad-mk1 [ Sun Aug 02, 2009 3:17 am ]
Post subject:  Cam question very noob!
Hey all looking at the cam listed in the for sale section
Question is is there different cams between 1275 and 1098 ?
Probably a silly question but one that had to be asked !
Cheers Jamie :)
Author:  92 [ Sun Aug 02, 2009 5:24 am ]
A 1275 cam can be fitted to a 1098 no worries
Standard the small bore cams only have 3/8' wide lobes where as a 1275 has 1/2' wide lobes which are better.
Any decent cam grinder will stamp the end of the cam to tell what the cam has been ground to.
Author:  meeni [ Sun Aug 02, 2009 7:40 pm ]
make sure the oil pump drive is the same..
Author:  drmini in aust [ Sun Aug 09, 2009 4:39 pm ]
Note that Cooper S pin drive oil pumps are now NLA, and so are the spider (star) adaptors for Morris 1100S/Mini 1275LS to fit their splined shaft pump.
I have steel laser cut adaptors in stock which will convert either type cam to take the 1275A+ slot drive pump. These pumps are the most commonly available now.
See my thread (with pics) in the mods forum-
http://www.ausmini.com/forums/viewtopic.php?t=39787
Author:  TheMiniMan [ Sun Aug 09, 2009 4:46 pm ]
Hey kev,,, i think i will have to order a few of these adaptors from you (like maybe 10) ,,, i`m running out of spider cams & need to set up small bore cams into the Bimmer engines , by cutting all the lobes off them & fit those adaptors should do the trick & i can use the late slot drive pumps then
i`ll bell you next week sometime if that`s ok?
Author:  drmini in aust [ Sun Aug 09, 2009 4:53 pm ]
PM sent. :wink:
Author:  TheMiniMan [ Sun Aug 09, 2009 4:55 pm ]
PM recieved & Reply sent
10-4 big buddy :-)
