It is currently Fri Jul 18, 2025 12:43 pm
PostPosted: Mon Aug 24, 2009 4:40 pm
Does anyone one the paint colour they sprayed the engines back then ?
Its an Aussi built 850.
PostPosted: Mon Aug 24, 2009 5:49 pm
Supercharged
my original 64 engine has the light green metallic paint
i believe the pommy crate engines for the earlier 850's had dark green.
chuck up your engine number and we can prolly tell you what colour its supposed to be.
PostPosted: Mon Aug 24, 2009 10:00 pm
green..
PostPosted: Tue Aug 25, 2009 5:50 pm
Hi Super Mini
I dont have the plate - got the rest of the car :)
I was talking to these guys http://ppcco.com.au/enamel.htm
who said it was BMC Green.
Ill have to go and get the plate off the mini owner and get back to you
Thanks
Cush :)
PostPosted: Tue Aug 25, 2009 6:05 pm
Supercharged
the number is stamped on the block of the engine also.
PostPosted: Tue Aug 25, 2009 10:10 pm
JasOn,
Contact AWOODY (Grant) he had his done recently in the correct colour.
Brian
PostPosted: Mon Sep 21, 2009 7:24 pm
Here is my 1964 850 starter motor which i believe to be original paint and the slave cylinder which i had mixed up to match. Hope it helps.
PostPosted: Wed Sep 23, 2009 9:25 pm
i have 2 colours so far - both Austin engines
This colour is the same as BMC Green produced by POR 15 www.por15.com.au supplied by PPC (Permenant Painted Coatings Pty Ltd,Warriewood NSW)
Quality engine paint but bloody expensive.
By Jas0n
This colour is the same as paint found on timing cover of AUS built Morris 850 im working on.
By Jas0n
Parts just sprayed with BMC Green
By Jas0n
Note - the good side with no runs :P
PostPosted: Wed Sep 23, 2009 9:33 pm
Thanks Grey 64 - that colour seems lighter again - is your 850 Aussie built ?
PostPosted: Wed Sep 23, 2009 9:41 pm
Info from AWOODY (Cheers mate)
1 British standard middle bronze green BS223
2 Dark bronze green BS 381c for a darker finish
By Jas0n
Standard British Green looks the go for my 850 - will have to respray those bits.
Apparently English built Morris Mini didnt have the gearbox sprayed green (left as unpainted alloy) and the Aussie built 850's sprayed both engine and gearbox.
PostPosted: Sat Sep 26, 2009 9:19 am
Finally have the engine number
8Y/U/H2152
thanks
PostPosted: Sat Sep 26, 2009 12:05 pm
8Y/U/H2152
thanks
Cool , an early Australian assembled engine , your body number would be around 43,000 (up to 45,000 , they switched between 8AM and 8YUH engines a bit through there) wouldn't it ?
Users browsing this forum: No registered users and 23 guests
