It is currently Sat Jul 19, 2025 6:40 am
 Post subject: Timing Gear
PostPosted: Mon Oct 05, 2009 11:52 am
Hi all,
I'm trying to put my timing gear back together on my motor (1275 out of a 1100S) and I have run into a problem, the screws that im sure came out of there seem to be to long to get back in. I was wondering if anyone one had an exploded diagram of the timing gear as my workshop manual doesnt seem to have a picture that is helpful.
Any help would be greatly appreciated!!!
Hi-Ho Silver LS1275
PostPosted: Mon Oct 05, 2009 12:59 pm
Mods rock!
If these are the 2 x 1/4" UNF screws that screw in to the Main Bearing Cap, under the crank spocket, they are counter-sunk if you are running a duplex chain / sprockets (which is standard on the 1100S). Don't forget - new chain means new gears.
 Post subject: Re: Timing Gear
PostPosted: Mon Oct 05, 2009 5:36 pm
MiniMe87 wrote:
Hi all,
Don't forget to fit the engine plate that goes between the block and the timing chain cover. It goes on before the cam retainer.
PostPosted: Mon Oct 05, 2009 8:20 pm
thanks for the help. i found the issue that was casing the prob......was a...........small operator error :lol: was using the wrong bolts was using the bolts that bolt the gearbox onto the bottom end so they were longer and hence causing the confusion!
Now have a slightly different problem with a key (key from the keyway on the camshaft) growing legs and walking so that put an end to the rest of the timing gear as i now need to go find one :(
Hi-Ho Silver LS1275
