Excel seats https://www.ausmini.com/forums/viewtopic.php?f=5&t=59767 |
Author: | kirby [ Tue Dec 22, 2009 5:41 pm ] |
Post subject: | Excel seats |
Ive seen some people say they are using excel seats in there minis. Just wondering if you could explain how you fitted them possibly with pictures? In a roundy btw. And as I understand in vic there is no need to engineer if im using the standard brackets. |
Author: | Kennomini [ Tue Dec 22, 2009 11:31 pm ] |
I think mounting the seat to the mini bracket may be a bit hard seeing as they are completely different. You most probably will need at least a customized bracket between the mini mount and the excel mounting point, this will be the item that needs to be approved, if you understand what I mean. Also how are you mounting the rear of the seat ![]() ![]() Good luck with it all though. P.S. This topic should probably have been put in "mini chat" seeing as it is not a question about A or A+ engines, you will probably get more responses in mini chat as well ![]() |
