It is currently Fri Jul 18, 2025 7:02 pm
PostPosted: Thu Jan 21, 2010 1:13 pm
Can you do it if you do the carb in a pressurized box trick?
PostPosted: Thu Jan 21, 2010 1:32 pm
Carby needs to be sealed & of course the plenum...
Suck through is really the only way with a standard carburettor.
 Post subject: blow through
PostPosted: Thu Jan 21, 2010 1:41 pm
Are you bored cushy???
PostPosted: Thu Jan 21, 2010 2:09 pm
Supercharged
you can seal it to handle boost, i'm not sure but maybe the bits from the metro turbo carb.
PostPosted: Thu Jan 21, 2010 6:35 pm
The turbo carbs had an o-ring to seal the dashpot and seals 'round the throttle shaft to stop letting air out. And a connection from the manifold side of the carb to the float (to equal pressure, making the carb work normal).
Doesn't sound too hard to recreate, does it? :)
http://666kb.com/i/bg0gu12ilng4lupzj.jpg
PostPosted: Thu Jan 21, 2010 7:42 pm
Don't you need a float that won't crush under pressure as well? (i.e. not hollow)
Not tried it mind, just what I've read.
Madmorrie
PostPosted: Thu Jan 21, 2010 8:17 pm
I remember discussions years ago on a message bored about converting a standard HIF to Turbo setup, just cannot remember most of the details....
The shaft seals are the std ones put on the shaft backwards to stop air escaping rather than stopping air being sucked in
Edit! - here you go -
NA SU blow through setup
Kevin
PostPosted: Thu Jan 21, 2010 11:04 pm
its easy as. Been done to death on turbo minis and the other UK sites.
blokeinamoke wrote:
PostPosted: Thu Jan 21, 2010 11:05 pm
what has?
Rathcooles suggestion?
