Non-turbo SU in blow through turbo setup
https://www.ausmini.com/forums/viewtopic.php?f=5&t=60487
Author:  cush [ Thu Jan 21, 2010 1:13 pm ]
Post subject:  Non-turbo SU in blow through turbo setup
Can you do it if you do the carb in a pressurized box trick?
Author:  willy [ Thu Jan 21, 2010 1:32 pm ]
Carby needs to be sealed & of course the plenum...
Suck through is really the only way with a standard carburettor.
Author:  wobbles_55 [ Thu Jan 21, 2010 1:41 pm ]
Post subject:  blow through
Are you bored cushy???
Author:  Super-mini [ Thu Jan 21, 2010 2:09 pm ]
you can seal it to handle boost, i'm not sure but maybe the bits from the metro turbo carb.
Author:  Asphalt [ Thu Jan 21, 2010 6:35 pm ]
The turbo carbs had an o-ring to seal the dashpot and seals 'round the throttle shaft to stop letting air out. And a connection from the manifold side of the carb to the float (to equal pressure, making the carb work normal).
Doesn't sound too hard to recreate, does it? :)
http://666kb.com/i/bg0gu12ilng4lupzj.jpg
Author:  madmorrie [ Thu Jan 21, 2010 7:42 pm ]
Don't you need a float that won't crush under pressure as well? (i.e. not hollow)
Not tried it mind, just what I've read.
Madmorrie
Author:  rathcoole [ Thu Jan 21, 2010 8:17 pm ]
I remember discussions years ago on a message bored about converting a standard HIF to Turbo setup, just cannot remember most of the details....
The shaft seals are the std ones put on the shaft backwards to stop air escaping rather than stopping air being sucked in
Edit! - here you go -
NA SU blow through setup
Kevin
Author:  mini-dunger [ Thu Jan 21, 2010 11:04 pm ]
its easy as. Been done to death on turbo minis and the other UK sites.
Author:  cush [ Thu Jan 21, 2010 11:05 pm ]
what has?
Rathcooles suggestion?
