Make sure the block has matching main bearing caps. God only knows why or how these get seperated, but there have been a number of blocks for sale without main bearing caps. Yes, you can have new ones made and line bored but will cost considerable $$.
Yes, as leighton says, the push rods are longer. There's also all the other anciliary items you'll need;-
Front engine plate,
Timing Chain cover,
Oil Filter head and pipe work,
All the fasteners (don't take this lightly, unless you have a 'treasure chest'),
Distributor Drive and collar,
Oil pressure relief valve cap,
Top Radiator Bracket (these are different to small bore),
Depending on the gearbox you will be running, the 'front' engine steady,
Primary Gear (yes these too are different to small bore and can be quite expensive),
Harmonic Damper,
Rear Alternator Bracket,
Rocker Cover,
Possibly the spyder for the Oil Pump (the doc has a conversion adaptor)
Thermostat housing to suit your radiator,
Distributor.
(I have tried to confine this list to a 'long' engine)
Depending on if you have a 'donor' engine, small or big bore, some of these items could be ratted from that.
I'd suggest buying new Big End Bolts & Nuts, Mains Bolts, Head Studs & Nuts, new Flywheel Bolt, new cam followers (although this should be done as part of the reco process), pistons, bearings (including cam and cam thrust plate), water pump.
Make sure the rods are the correct ones to suit the crank. There were Large and Small Jounal Big End Cranks. The small jounal are far less popular (mostly Cooper S) and same for the rods, but it could pay to check.
This poject will cost some considerable $$ so be prepared for that.
You can pick up a - more or less - complete, 1275 engine (block, rods, head, crank, primary gear, assembly 'out of car') for $250 to $500, so put that in to perspective of what you are considering.
<EDIT> You could also be up for Valves and valve springs.
