Hi Micheal!
That's lots more than I'm expecting
113lb/ft is imense!
I like the idea about a continuous diameter from start to end.
What I got from APTfast about the cam:
"This cam is a hot street cam, ideal for 1275cc and bigger. Intended for use with 1.5 ratio rockers, but could be used with standard or "tweaked" rockers to make it a little more docile with better torque below 4000 RPM. Lobe center angle 102.5/105.5, duration@ 0.020" In./Ex. 268-272°, cam lobe lift 0.312-0.319, lash clearance (hot - max) 16 In. /18 Ex. RPM range 2200-7200, Max. RPM 7600, idle Characteristics slighty lumpy, suggested comp. ratio 9.0-10.4. Cam duration @0.050 lift 234/242"
Also it's a scatter pattern profile
Jan
