Oil Filter Sandwich Plate https://www.ausmini.com/forums/viewtopic.php?f=5&t=62313 |
Author: | albino235 [ Thu Apr 08, 2010 7:31 pm ] |
Post subject: | Oil Filter Sandwich Plate |
Hi, I am trying to find a thermostatic oil filter sandwich plate for the spin on filter but I don't have one here to measure, so does anyone know the thread size/type and the O ring diameters for the spin on filter? Or alternatively, has anyone bought one of these and can point me in the direction of a supplier? Also, does anyone know the thread size/type of the banjo bolt fitting in the block that runs to the filter housing? I want to replace this with a flexible hose, so I just need to know what fittings I need to order. Cheers, Alex |
Author: | drmini in aust [ Thu Apr 08, 2010 7:46 pm ] |
Can't help you on the filter sandwich plate. The banjo bolt thread in the block though is 5/8-18 UNF. Karcraft sells the proper fitting to go to 1/2 BSP oil hose (Cooper S etc). Or, you can make them from a brass 1/2BSP x 3/8BSP brass nipple (Bunnings sell them cheap)= just machine the 3/8BSP end down to 0.625" diameter and run a 5/8 UNF die nut down it in a lathe. ![]() |
