Link Automotive supercharger? https://www.ausmini.com/forums/viewtopic.php?f=5&t=63772 |
Page 1 of 2 |
Author: | MINIRO [ Wed Jun 16, 2010 6:51 pm ] |
Post subject: | Link Automotive supercharger? |
Looking at different ways to modify the heart of my mini, different engines etc, but thinking rather than going thru all the engineering hell of a different make engine, maybe just a supercharged baby instead, has anybody got 1 of these? What are they like?, performance wise, fuel consumption etc cheers & thanks Rohan |
Author: | EAB [ Thu Jun 17, 2010 12:51 am ] |
I'm assuming you've checked this out already http://www.hi-flow.com/HP3MiniSuper.htm Thats the kit sold through link. a lot of other people on here are using bens sc12 kit. |
Author: | MINIRO [ Thu Jun 17, 2010 10:15 am ] |
EAB wrote: I'm assuming you've checked this out already
http://www.hi-flow.com/HP3MiniSuper.htm Thats the kit sold through link. a lot of other people on here are using bens sc12 kit. what's the sc12 kit? |
Author: | EAB [ Thu Jun 17, 2010 10:32 am ] |
the SC12 kit is a manifold and other parts developed by Ben (and others?) who is a member on the forum. It uses the SC12 supercharger which was used on older Toyotas like the AE86 and various others. It fits into the mini with little modification. Bens kit comes with all the parts you need to install it. You need the actual supercharger and a carby tho. pm him for more details or do a search for it. heaps of info on the forum http://www.ausmini.com/forums/profile.php?mode=viewprofile&u=919 |
Author: | NG [ Mon Jun 21, 2010 10:01 pm ] |
Im also setting one up! ill let you know when i get it done you are more then welcome to check it out. should be all going in maybe 2 months. should have about 80 to 90Atw's and totally workable for a everyday car ![]() just drop the compression of the head & maybe strengthen few things if you want to. run a cross pin diff. and you need a mild cam. like a 266 or 276. could go a re13T they make good power like O=MY GOD! power. at a gear box price ![]() http://www.miniaddicts.co.uk/forum/show ... php?t=2197 that will show you everything you need to know ![]() |
Author: | MINIRO [ Fri Sep 10, 2010 8:27 pm ] |
Rang Link Automotive today ![]() abit more than i was thinking (not by much tho) either way when the time comes, it is the road i will be going down ![]() i only want to build this mini once, not again in 5years time etc... Cheers Rohan |
Author: | simon k [ Fri Sep 10, 2010 8:47 pm ] |
MINIRO wrote: got costings on a complete engine incl S/C..
$8K ? |
Author: | MINIRO [ Fri Sep 10, 2010 9:06 pm ] |
simon k wrote: MINIRO wrote: got costings on a complete engine incl S/C.. $8K ? minus S/C ![]() ![]() should mention that includes them buying an A+ engine/box as i dont have a donor engine for them.... |
Author: | DTrain [ Fri Sep 10, 2010 9:59 pm ] |
there are a couple on ebay cheap |
Author: | Bubbacluby [ Fri Sep 10, 2010 11:20 pm ] |
um wow thats a lot of money for a supercharged motor, that i assume would not a 'off its nutter' s/c motor?? OR is that fully worked - ie head flowed, lightened conrods, cross-pin/AT diff etc Does that include a gearbox as well? |
Author: | Hanra [ Fri Sep 17, 2010 12:58 pm ] |
That Link kit used to be around the $5500 mark from memory. |
Author: | slide [ Fri Sep 17, 2010 5:58 pm ] |
You can now get a crossflow head and twin webers for a lot less. |
Author: | Ziegech [ Sun Oct 10, 2010 12:52 pm ] |
Bens SC12 Kit is great fun and if you have a motor already together its an easy bolt on performance. However a strong new engine and gearbox is a good idea. Also Link can tune them up for you if you have trouble with the carby. |
Author: | michaelb [ Sun Oct 10, 2010 5:39 pm ] |
The Vmaxscart kit with Eaton M45 Charger cost me around 2.8k delivered to Sydney. Now for the engine build. Not sure on this yet? |
Author: | Babes [ Sun Oct 10, 2010 9:24 pm ] |
Im bolting my vmax kit onto a metro turbo engine and box, its getting oh so very close to finished ![]() |
