EDIS Spark Plug Leads https://www.ausmini.com/forums/viewtopic.php?f=5&t=63888 |
Page 1 of 3 |
Author: | jb007 [ Mon Jun 21, 2010 6:34 pm ] |
Post subject: | EDIS Spark Plug Leads |
Hi all that have fitted EDIS to their cars. What spark plug leads did you use? I know the length depends upon where you mount the coil pack, but I have some latitude in mounting this somewhere around the right side of the cylinder head or just in front of it on the right side (below #4 spark plug). Trolling the Internet some say that Ford KA or Fiesta leads are a good fit. Jim. |
Author: | NG [ Mon Jun 21, 2010 10:07 pm ] |
you can buy heaps of kits via the uk ![]() search http://www.turbominis.co.uk/ ![]() |
Author: | mini_mad_matt [ Mon Jun 21, 2010 10:09 pm ] |
I think someone mentioned they just shoved their old mini leads onto the coil. I personally just got the leads that came with the coil but i haven't fitted it yet. Another option is make your own, this isn't that hard to do really and would be a lot cheaper then buying a set of ford KA or fiesta leads, as they will set you back around $100. I'm not sure if the usual repco/autobahn etc sell lengths of leads and the necessary ends though. It's worth looking into. |
Author: | NG [ Mon Jun 21, 2010 10:19 pm ] |
you can get some made as well. yellow pages! i got some made for my mini with standard ends & one a bit longer as i run aircon. was $50 or so. ![]() |
Author: | jb007 [ Mon Jun 21, 2010 10:20 pm ] |
mini_mad_matt wrote: I think someone mentioned they just shoved their old mini leads onto the coil. I personally just got the leads that came with the coil but i haven't fitted it yet.
Another option is make your own, this isn't that hard to do really and would be a lot cheaper then buying a set of ford KA or fiesta leads, as they will set you back around $100. I'm not sure if the usual repco/autobahn etc sell lengths of leads and the necessary ends though. It's worth looking into. Thanks for that. The coil towers on the coil pack take an unusual style lead connection that I've not seen before. If I could get the correct ends, I would modify a standard set of leads other wise I can get Ford KA leads for ~ $70, and if required shorten them. |
Author: | jb007 [ Mon Jun 21, 2010 10:26 pm ] |
NG wrote: you can get some made as well.
yellow pages! i got some made for my mini with standard ends & one a bit longer as i run aircon. was $50 or so. ![]() Will look into this... let your fingers do the walking! ![]() |
Author: | simon k [ Mon Jun 21, 2010 10:39 pm ] |
pfft - standard leads $5 each from supercrap... same ones I had on my pulsar dizzy ![]() |
Author: | jb007 [ Mon Jun 21, 2010 10:52 pm ] |
simon k wrote: pfft - standard leads $5 each from supercrap... same ones I had on my pulsar dizzy
So your point is that standard lead ends can be made to fit? ![]() |
Author: | simon k [ Mon Jun 21, 2010 10:58 pm ] |
jb007 wrote: simon k wrote: pfft - standard leads $5 each from supercrap... same ones I had on my pulsar dizzy So your point is that standard lead ends can be made to fit? ![]() yeah, I just shoved them on - I think it was 14 months and maybe 10 motorkhanas ago now... no sign of them coming off, and I pressure wash the motor at the car wash Pristic did that with his, I was going through the pain of trying to find leads and he said he'd just jammed the standard ones on |
Author: | jb007 [ Tue Jun 22, 2010 9:50 am ] |
simon k wrote: jb007 wrote: simon k wrote: pfft - standard leads $5 each from supercrap... same ones I had on my pulsar dizzy So your point is that standard lead ends can be made to fit? ![]() yeah, I just shoved them on - I think it was 14 months and maybe 10 motorkhanas ago now... no sign of them coming off, and I pressure wash the motor at the car wash Pristic did that with his, I was going through the pain of trying to find leads and he said he'd just jammed the standard ones on Thanks Simon, looks like you have started a trend! ![]() ![]() ![]() |
Author: | afh001 [ Tue Jun 22, 2010 10:11 am ] |
You can get the EDIS coil pack clips here: http://www.boostengineering.net/category_s/1.htm If your tricky you can even remove the clips, terminals and boots off the old mondeo leads and swap them onto another set, but it seems a bit of a waste of time if the standard leads jam on there! Andrew |
Author: | simon k [ Tue Jun 22, 2010 10:18 am ] |
jb007 wrote: Thanks Simon, looks like you have started a trend!
![]() ![]() ![]() not so much started the trend, just taken it mainstream.... I have the leads with the locking clips that came with my coil pack, I started to take them apart to make new leads, then thought "screw this, I'll do that if pushing the standard ones on doesn't work" BTW - the coil pack is basically generic, you can use a coil pack off a few different cars, the EDIS is the little black box which is the important part... |
Author: | jb007 [ Tue Jun 22, 2010 10:23 am ] |
afh001 wrote: You can get the EDIS coil pack clips here:
http://www.boostengineering.net/category_s/1.htm If your tricky you can even remove the clips, terminals and boots off the old mondeo leads and swap them onto another set, but it seems a bit of a waste of time if the standard leads jam on there! Andrew Just bought some from them! Thanks for that link. ![]() |
Author: | MINIRO [ Tue Jun 22, 2010 12:00 pm ] |
Have just come across this "electronic ignition" setup, I'm assuming this so that we don't have cough n splutter issue when driving in the wet? Might have look into this ![]() Rohan |
Author: | Mick [ Tue Jun 22, 2010 12:07 pm ] |
This concerns me... Quote: EDIS 4 Ignition Leads
Part is Used Guaranteed Functional. |
Page 1 of 3 | All times are UTC + 10 hours |
