It is currently Wed Jul 09, 2025 10:28 am
PostPosted: Tue Aug 31, 2010 11:56 am
Hi Guys,
Anyone got any thoughts on toothed-belt drive for water pump and alternator?
Cheers.
Caring about your job is for people without lives.
PostPosted: Tue Aug 31, 2010 12:10 pm
isn't it already belt driven?? am I missing something here?
PostPosted: Tue Aug 31, 2010 12:11 pm
Waste of time.
If I was to bother converting to a different type of belt, it'd be a poly ribbed vee.
PostPosted: Tue Aug 31, 2010 12:57 pm
I bet the toothed belt drive would sound a whole lot better thou. :twisted:
2008 Prado GXL
PostPosted: Tue Aug 31, 2010 1:35 pm
Hmmm. Yes to all the above. Was thinking toothed-belt so that I can keep the alternator spinning without flogging-out the water-pump bearing.
PostPosted: Wed Sep 01, 2010 9:03 pm
nah..... our water pumps do fine don't they?
you can buy a toothed belt drive kit from minispares etc. but they run a pair of belts, one up to the water pump, then another from the water pump to the alternator
PostPosted: Thu Sep 02, 2010 10:10 am
Had a 2inch gilmer drive setup on the supercharged black car. Sounded friggen awesome. Anyone who saw the car at the muster (the commentator had me firing it up all day) Unless you have a blower on it probably not much advantage but worth the expense just for the sound it made.
1962 Mini Speed sports sedan
