The drive straps are about .035" thick.
Putting an extra one in reduces the assembled height of the diaphragm spring, and hence its clamping load. It's not just a question of release bearing position.
The spring should be
flat (parallel to the flywheel) when assembled with a NEW clutch plate. This is most important with big torquey NA motors or turbo ones.
I assemble the clutch on the bench then use a 1/8" drill bit held against the spring, and a torch, to check this.
Often with old worn/machined flywheels and backplates they are miles out- one I did recently needed .070" off the 3 backplate lugs to make it correct.
If you've not done so already I suggest you read Marcel Chichak's story on how to correctly set up a Mini clutch.
http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
BTW my 1360 roady has somewhere near 130HP at crank, it runs just fine with 2 straps, an orange diaphragm and standard AP clutch plate.
Ditto my 1412 stroker, with 112 ft/lb torque.
