Pre-engaged Starter Motor v Hi-Torque https://www.ausmini.com/forums/viewtopic.php?f=5&t=67398 |
Author: | Cooper_Matrikon [ Wed Dec 01, 2010 11:26 am ] |
Post subject: | Pre-engaged Starter Motor v Hi-Torque |
Wondering if I should upgrade to a hi torque starter motor. Barney seems to labour a little at startup and I think a nice whirring geared starter might do the trick. Ideas? |
Author: | graham in aus [ Wed Dec 01, 2010 5:32 pm ] |
Pre-engaged would need a different ring gear (A+) or why not, a lightened flywheel and ring gear? really should be balanced then though. I assume you can get Hi torq to suit a series ring gear I think Tony (MiniConvertible) up in QLD can sort you! ![]() |
Author: | drmini in aust [ Wed Dec 01, 2010 6:13 pm ] |
Barney already has a new geMini starter, if you are having problems it's time for a new battery mate. It is pre-engaged already, using the early mini ring gear, NOT the later Rover one. This starter spun it like a top when the battery (Exide 550CCA) was new. Maybe Marc changed the battery, or it's had it... C/R on your 1293A+ motor (21251 pistons, slightly decked head) is only about 9.0:1. Spinning it over is not a problem. ![]() |
Author: | wobbles_55 [ Wed Dec 01, 2010 7:25 pm ] |
Post subject: | starters |
Also check your terminals and all power cables going to the starter... and while your at it check all of your earth straps. |
Author: | 1310/71 [ Wed Dec 01, 2010 7:45 pm ] |
I know someone who installed a switch so you spin the motor up before you power the points ![]() |
Author: | drmini in aust [ Wed Dec 01, 2010 8:22 pm ] |
1310/71 wrote: I know someone who installed a switch so you spin the motor up before you power the points
![]() Yeah do tell, but he has to run 38° total advance due to the bathtubbed head shape and big cam. Which means static timing with the GR modded Pulsar dizzy is about 20°BTDC. No, it doesn't ping either. ![]() |
Author: | Cooper_Matrikon [ Thu Dec 02, 2010 9:15 am ] |
Will start with a battery then. I know the old man had to give it a charge when I was in Canada as it would run flat about every 10 days. I thought it may have been something to do with the advance, but a battery is a good place to start. |
Author: | drmini in aust [ Thu Dec 02, 2010 9:21 am ] |
I put an Exide 550CCA in when we bought it so if that's still there, it's a few years old now. I have the same type battery (same age too) in my 1360/1412 car, this past winter I went very close to changing it for the same reason. But if I drive it once a week it'll survive until May next year. ![]() If you buy a new battery, get the biggest output one that'll fit in there. Similar to what I said above. |
Author: | Cooper_Matrikon [ Thu Dec 02, 2010 9:22 am ] |
Well Barney runs every day, so there's life in the battery yet. Will stick it on the list. Doc, are you planning on going to Oz50 at WP? |
Author: | drmini in aust [ Thu Dec 02, 2010 9:24 am ] |
Cooper_Matrikon wrote: Well Barney runs every day, so there's life in the battery yet. Will stick it on the list. Doc, are you planning on going to Oz50 at WP?
Yeah we'll go for a look, but I'm not going to get a CAMS licence just so I can do some laps. ![]() |
Author: | Cooper_Matrikon [ Thu Dec 02, 2010 9:25 am ] |
You can get an AASA licence for $50. I'm going to run Barney in reg (at a spirited, yet relaxed pace). |
