chewed out drum brake screw removal
https://www.ausmini.com/forums/viewtopic.php?f=5&t=68470
Author:  850pete [ Tue Jan 25, 2011 8:29 pm ]
Post subject:  chewed out drum brake screw removal
G'day guys,
I've got a chewed up screw head on one of the drum retaining screws on the front of my 850, i've tried tapping at it with a small cold chisel to try and get it to free up but she's not budging readily.
Has anyone got any ideas thats has worked before, I've thought about MIG tacking a nut onto the screw and undoing it with a socket and ratchet? any pitfalls to this i should be aware of??
Thanks in advance.
Pete
Author:  Morris 1100 [ Tue Jan 25, 2011 8:32 pm ]
The easiest way is to drill the head off the screw and then remove the drum and attack the screw with vice grips and Penetrene®
Author:  drmini in aust [ Tue Jan 25, 2011 8:41 pm ]
Impact screwdriver. Best $5 I ever spent, many moons ago.
But if the slot is totally gone I'd do what M1100 said.
Author:  sgc [ Tue Jan 25, 2011 8:54 pm ]
I know someone else who swears by those too.. he was restoring a 911 and reckoned it was the best tool ever.
Author:  subwayseth [ Tue Jan 25, 2011 8:55 pm ]
+1...mine were also seized, a few solid whacks later & they were free
Author:  GT mowog [ Wed Jan 26, 2011 5:02 am ]
+1.
Author:  Wombat [ Wed Jan 26, 2011 6:09 am ]
+1.
+1 - hardly ever use it but when I do it's gold - oh and 2 out 3 times I get a blood blister at the base of the thumb :roll:
Author:  norton [ Wed Jan 26, 2011 12:20 pm ]
I have one with a 1/2'" drive so you can stick sockets on it too
Author:  850pete [ Fri Jan 28, 2011 1:41 pm ]
Post subject:  drums
Thanks for the replies guys, I initially tried the impact driver and thats what chewed the screw head so I got a drill onto it and drilled the head off, removed the drum with a touch of brutality and now have to finish off the rest of the screw.
I noticed the drum is dated 2month 62.......surely it can't be the original drums? there was plently of lining left on the shoes but the lining has separated.
Here's a pic of the drums
Author:  850pete [ Fri Jan 28, 2011 1:42 pm ]
Post subject:  62 drums
By the way my 850 was dated using the register as a September 62 build. Still only has single leading front brakes too
Author:  simon k [ Fri Jan 28, 2011 3:39 pm ]
Post subject:  Re: drums
I wouldn't be surprised... they didn't go fast enough to use enough brakes to wear grooves into the drums
there would be lots of unrestored cars getting around on original drums
Author:  drmini in aust [ Fri Jan 28, 2011 4:56 pm ]
I'm not surprised many cars here have old drums still.
Remember that here in Oz, brake shops remachined these 7" drums when worn, first to + 1/32" then to +1/16" diameter. They then bonded oversize linings to the shoes and radius ground them to the right oversize.
But in UK, I think they just tossed the drums when worn and fitted new drums and shoes. Parts then were much cheaper and more available there than here.
