SUPER CHARGE OR 7 PORT HEAD
https://www.ausmini.com/forums/viewtopic.php?f=5&t=69182
Author:  jcg2 [ Wed Mar 02, 2011 7:39 pm ]
Post subject:  SUPER CHARGE OR 7 PORT HEAD
So looking at doing some serious go go on my round nose.
I have a 1275 bored to 1330 with a 40mm webber goes great but i would love some more power.
So im either looking at sc12 charger kit or the 7 port alloy head with twin 40mm webber
what do you guys think?? im thinking cost factor they will both be similar price,
What sort of power should i be expecting from each, does anyone know??
http://cgi.ebay.com/ebaymotors/Crossflo ... ccessories
Author:  awdmoke [ Wed Mar 02, 2011 11:22 pm ]
Cost will depend on your current engine - what is your current compression ratio, or are you planning on a rebuild and new pistons anyway?
Also is it for mostly street or track?
Author:  jcg2 [ Thu Mar 03, 2011 7:22 am ]
Post subject:  Charge
Will be mainly street .. My engine has been rebuild not long ago so don't plan on doing that again.
Author:  Hanra [ Thu Mar 03, 2011 11:56 am ]
I had a thought about putting a SC on my car but I mean in reality it would be a $10k project by the end of it. Rebuilding motor/box/diff to handle extra torque and then buying the SC kit and a SC12... So expensive....
$10k would build one hell of a SBC.
Author:  Super-mini [ Thu Mar 03, 2011 12:31 pm ]
i vote for sc-12, because i have one and bang for buck it cant be beat.
Author:  awdmoke [ Thu Mar 03, 2011 1:35 pm ]
I went for an alloy 7 port head, as I already had a high compression stroker bottom end & changing pistons to reduce the CR was out of my budget.
Author:  mattsmadmini [ Thu Mar 03, 2011 2:09 pm ]
why not a Supercharged EFI 7 port? :twisted:
Author:  Hanra [ Thu Mar 03, 2011 2:10 pm ]
What is the price of the SC12 kit nowdays? Is there more then one type available? Are the kits still available new?
Author:  Super-mini [ Thu Mar 03, 2011 2:12 pm ]
just so you know, you can run low boost with standard compression
also, a decompression plate is pretty cheap, under $100 i think.
havent had any issues with mine, and its been running max boost etc.
also means you can return the engine to n/a if you wish.
its not the best way, but if you're on a budget or your engine is already built...
think they go for around $1200 with the charger, and a carb if you're lucky.
i was lucky and had a hs6 off a wreck, and sourced a sc-12 cheaply.
i'd estimate 80-90hp at the wheels based upon what i have seen other 1275's do.
we were lucky and had 3 sc-12 supercharged bigblock's on the same dyno same day.
Author:  jcg2 [ Thu Mar 03, 2011 5:28 pm ]
Post subject:  alloy head
think i might go for the alloy 7 port head guys..
Next question is how much more power will i gain with this engine from an already mild set up i have as a 1330. i have a very mild cam and some very mild head work already.
Author:  Lillee [ Thu Mar 03, 2011 6:50 pm ]
You won't gain much with just a "mild" cam. Change the cam too
Author:  SuperCooper [ Thu Mar 03, 2011 9:29 pm ]
FYI:
http://www.ausmini.com/forums/viewtopic ... &start=150
"Ok , so had the 7 port on the rolling road dyno today.
5 port head A+ 1360, 266 cam , 1.5 rrr, LCB , 45mm weber, standard 5 port head made 60hp atw @ 5750rpm, 3rd gear 110 kph.
Ported 7 port Pierce head Same dyno, same set up with twin 40mm dellortos. 10.5 cr. 3.1 diff.
90.4 hp atw @ 5870, 3rd gear ,118kph.
Still a bug to iron out around 3000 - 3500 rpm.
Needs : new exhaust - perry lcb has seen better days and is cracked! I noticed this the night before the dyno session , so disconected battery + and - , welded up the cracks and sorted the lower bracket and fried the alternator in the process. My advice - unplug your alt when welding!
Megajolt lite or a different dizzy - the A+ ducellier was not made for this application.
Pretty happy so far with a bit more to come , need to sort out the miss in middle revs to make it more driveable , probably a combination of advance curve/jetting.
Anyone else got thiers going?"
