1100 and sc14 build up https://www.ausmini.com/forums/viewtopic.php?f=5&t=70617 |
Author: | MINIDAD76 [ Tue May 10, 2011 1:01 pm ] |
Post subject: | 1100 and sc14 build up |
Hi guys, have read a lot about the sc12 units going on all sorts engines. I have an 1100 and a used in good nick sc14. I am about to start a long haul rebuild on both units. Can any one tell me what sort of lower compression is needed to run safely the sc14 for fast road/everyday driver.? Also, there is a kit to adapt sc12 to the 'A' series engines, is there this sort of kit for the larger sc14? Thanks |
Author: | simon k [ Tue May 10, 2011 1:54 pm ] |
Post subject: | Re: 1100 and sc14 build up |
MINIDAD76 wrote: is there this sort of kit for the larger sc14?
nup - Ben (maker of the SC12 kit) doesn't make one |
Author: | 92 [ Wed May 11, 2011 5:14 pm ] |
The trouble with a SC14 is trying to slow it down enough so you don't get too much boost whilst retaing a decent harmonic balancer. Then it goes too slow and is out of it's efficiency range. |
Author: | simon k [ Wed May 11, 2011 5:22 pm ] |
unless you went for something silly like 6:1 compression? but in doing so you'd be killing your low rpm drivability |
Author: | MINIDAD76 [ Thu May 12, 2011 9:44 am ] |
Thanks guys for your coments. I was not far from starting the sc14 rebuild and polish. Now looks like I might get rid of it and go the sc12 as you have suggested. If the 14 is for 2ltr motors then what is the smaller 12 from and can it do the job nicely? Also, 92, are you the one who makes the kits for these and have you any in stock if I can change to the 12? Thanks |
Author: | Clutch-monkey [ Thu May 12, 2011 9:58 am ] |
MINIDAD76 wrote: Thanks guys for your coments. I was not far from starting the sc14 rebuild and polish. Now looks like I might get rid of it and go the sc12 as you have suggested. If the 14 is for 2ltr motors then what is the smaller 12 from and can it do the job nicely? Also, 92, are you the one who makes the kits for these and have you any in stock if I can change to the 12? Thanks
iirc the SC12 is from the toyota 4AGZE engines, 1.6L donks found in AW11 MR2's and a few corolla's.. seem to do the job fine on A series engines? i would have thought it'd be fine for an 1100 |
Author: | simon k [ Thu May 12, 2011 10:08 am ] |
my car with the SC12 goes like a f*cking rocket - I'd love to see an engine on a dyno and compare an SC12 with the Link kit and a BMW blower |
