It is currently Fri Jul 18, 2025 12:09 pm
PostPosted: Tue Dec 20, 2011 7:44 pm
hey guys, bit of an issue my crankshaft pulley has busted into about 4 pieces.
im stuck with the inner part of it left. does anyone know how I can remove it? the nut is undone, but i sat it there so as not to loose it Image Image
PostPosted: Tue Dec 20, 2011 7:59 pm
You could try and carefully lever it off but be carefully not to damage the timing cover
Alternatively try a pulley remover, but not sure you have the space for this to fit?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Dec 20, 2011 8:12 pm
A 2 leg puller will work if you put a jack under the motor, then remove the engine mount & its bracket.
PostPosted: Tue Dec 20, 2011 8:41 pm
I just noticed! That looks like an easy way to get to the speedo cable, but I guess that is not what you were thinking :?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Dec 21, 2011 6:29 pm
did it just fly to bits or was it damaged trying to grt it of fthe crank shaft
PostPosted: Tue Dec 27, 2011 3:35 pm
smashed to bits while driving.
PostPosted: Thu Jan 26, 2012 1:30 am
Hello,
would you mind disclosing the brand name of the pulley/damper that failed? Thanks.
"it's always better to be uninformed than ill-informed"
PostPosted: Thu Jan 26, 2012 6:40 am
mini7boy wrote:
Hello,
Looks to be the standard pressed tin type used on 998s. Very easy to damage trying to get off. I had something similar when rebuilt to a 1185 but went to the 1275 type dampner.
Dave K.
PostPosted: Thu Jan 26, 2012 8:08 am
undo the bolt and warm the hub up with a oxy, then give it a tap to loosen it
PostPosted: Thu Jan 26, 2012 2:59 pm
It should be just a slide on fit, 2 screwdrivers will get that off.
You won't do it any more damage... :lol:
Users browsing this forum: No registered users and 23 guests
