honda caliper mounting Brackets https://www.ausmini.com/forums/viewtopic.php?f=5&t=7553 |
Author: | chasg [ Wed May 25, 2005 8:48 pm ] |
Post subject: | honda caliper mounting Brackets |
Can you make the caliper mounting brackets out of 10mm thick mild steel ? The drawing l have says 8mm thick steel. The reason l am asking is because l may be able to get some sets made as a training exercise for the students at the Tafe where l work and they only have 6mm or 10mm thick mild steel |
Author: | TK [ Wed May 25, 2005 9:01 pm ] |
buy some 8mm? nah use 6mm and use 2mm washers. easy |
Author: | drmini in aust [ Wed May 25, 2005 9:27 pm ] |
Yes you can get 8mm. I bought 130x8 flat bar from Bohler Steel. ![]() Actually 8mm is a bit thick- the ones I did for kazjim I had to mill back to 7mm, where the caliper bolts on. |
