Steering column spline supplier?
https://www.ausmini.com/forums/viewtopic.php?f=5&t=75672
Author:  AndrewG_1275* [ Sat Feb 25, 2012 12:13 am ]
Post subject:  Steering column spline supplier?
Hi, just wondering if anyone knows who can supply the end spline part for Mini steering columns? Apparently a guy in Queensland makes them but having trouble getting any info. They are available from Minisport but are quite expensive!
Any help / suggestions who to try greatly appreciated.........
Author:  drmini in aust [ Sat Feb 25, 2012 7:22 am ]
Mini King has some original factory forgings, but they are unmachined.
I got prices recently for machining them, but the cost was prohibitive.
I then got a price to CNC machine some from bar stock and wire cut the splines in, the minimum qty worth making was a problem, & it was expensive too.
The main problem to do them cheaply is finding someone with a 9/16 x 36 tooth SAE spline pull-thru broaching tool, or putting up the $$$$ to get one made. Nobody knows what happened to the original tooling back in 1978 or whenever.
The next problem is welding them onto the shaft- these days they would probably need to be TIG welded by a certified welder.
Author:  Wombat [ Sat Feb 25, 2012 10:57 am ]
This mob is in Qld http://www.gearconcern.com.au/contact.htm
Author:  Wombat [ Sat Feb 25, 2012 11:00 am ]
Why isn't my post showing ???
Author:  Wombat [ Sat Feb 25, 2012 11:04 am ]
http://www.gearconcern.com.au/contact.htm are in Qld
Author:  AndrewG_1275* [ Sun Feb 26, 2012 8:18 pm ]
Hi Dr Mini and Wombat!
Thanks both of you for that info, will give them a try this week!
CHEERS, AG!
Author:  TheMiniMan [ Sun Feb 26, 2012 8:41 pm ]
Tony & Andrew from Minisport Australia (Adelaide) have these end pieces in stock
Author:  drmini in aust [ Sun Feb 26, 2012 9:28 pm ]
Geez and I thought my CNC quote was dear!!! :shock:
[edit] But I'm glad to see they are available for those in need.
8)
http://minisport.com.au/prod2222.htm
Author:  TheMiniMan [ Mon Feb 27, 2012 9:26 am ]
i was going to get my Guy to make them (a while ago) but there wasn`t really very much support or encouragment,,, i could have probably made them avaliable for about $60 each but like i said, there just wasn`t anyone interested & a whole heap of people kept telling me that minisport already have them,,, so i didn`t really want to step on anyones toes,,, so i didn`t bother making them,,, i`m making other stuff instead :-)
