It is currently Sat Aug 09, 2025 7:38 pm
 Post subject: Skimmed 295 head
PostPosted: Sun Apr 30, 2017 9:27 am
Is 100 though too much to take off a 295 head?
 Post subject: Re: Skimmed 295 head
PostPosted: Sun Apr 30, 2017 10:40 am
why ruin a rare head? Get high compression pistons, flat tops are available.
PostPosted: Sun Apr 30, 2017 10:46 am
So 100 thou is going over the top? Will the head still be functional?
PostPosted: Mon May 01, 2017 9:41 am
These days I would not take more than .075" off any early small bore head, including the 295. Max .060" off is safer.
Reasons:
1. They had a much thinner deck than 1275heads when new.
2. After 50 years of corrosion they are even thinner in there. Expect head gasket leaks if you rip too much off.
