Shimming ball joints
https://www.ausmini.com/forums/viewtopic.php?f=5&t=78194
Author:  Klaery [ Sun Aug 26, 2012 8:41 pm ]
Post subject:  Shimming ball joints
Can anyone tell me when adjusting the ball joints with shims, do you shim both top and btm joints or only the top as the btm are spring loaded.
Thanks for any help
Author:  mickmini [ Sun Aug 26, 2012 8:46 pm ]
shim them both, but remove the spring while doing the shims on the bottom ones. Put the springs back in once you are done.
michael
Author:  Harley [ Sun Aug 26, 2012 8:46 pm ]
Work out the shims you need with the spring removed, then refit and assemble properly.
Author:  Klaery [ Sun Aug 26, 2012 9:20 pm ]
Thanks.
I'll get this car back on the road yet.
Author:  drmini in aust [ Mon Aug 27, 2012 8:19 am ]
Use a new locktab washer (unless the old one has 3 spots not bent up before).
Torque the big cap up to 72 ft/lb, no less. If it comes undone at speed on the road, the result is not pretty (been there as a passenger...) :shock:
