rocker ratio's https://www.ausmini.com/forums/viewtopic.php?f=5&t=79040 |
Author: | justfanginaround [ Thu Nov 01, 2012 10:24 am ] |
Post subject: | rocker ratio's |
I'm wondering what the ratio's are for the pressed steel, forged "S" and the sintered rocker arm are. Just kinda curious. |
Author: | drmini in aust [ Thu Nov 01, 2012 10:33 am ] |
A while ago I set up an RE13 cam (.290" lobe lift) in a block, put a 12G940 head on it and tried a bunch of different rockers. I will dig out the file I wrote shortly, but from memory- S forged rockers, 1.16:1 Sintered A+ etc rockers, 1.18:1 Pressed steel 850/998/1098 rockers, 1.20 or 1.21:1 None of em got anywhere near the 1.25 that people think they are... ![]() [edit] Pressed steel rockers with my 0.044" offset bushes, got 1.31:1. 1275 oval pad pressed steel rockers with these same bushes got 1.35:1. Both tested on the same head/block/cam setup. |
Author: | justfanginaround [ Thu Nov 01, 2012 10:40 am ] |
thanks doc for the very quick reply ![]() |
Author: | drmini in aust [ Thu Nov 01, 2012 11:08 am ] |
Here's the lift figures, the head was a 12G1316 (1275 smog head)not a 940 as I said. Rocker ratio = (valve lift " + .016" clearance)/.290" lobe lift 22/7/07 Checked valve lift- 12G1316 head fully assembled. RE13 cam, stock pushrod, valve clearance .016”: Lift at #1 inlet valve- S forged rockers 0.321” A+ sintered rockers 0.327” 998 Deluxe rockers, cast iron posts 0.337” 998 Deluxe rockers, A+ sintered posts (are 0.3mm shorter than CI) 0.339” 998 Deluxe rockers, cast posts lowered 0.6mm, offset bushed 1.0mm. 0.359” 998 Deluxe rockers, cast posts lowered 0.6mm, offset bushed 1.1mm 0.365”(1.31:1) Toyota Corolla rockers, late `sintered rocker’ type posts, shaft offset 3.9mm 0.402”(1.44:1) |
