painting hood lining... https://www.ausmini.com/forums/viewtopic.php?f=5&t=7952 |
Author: | 64mini [ Thu Jun 09, 2005 4:23 pm ] |
Post subject: | painting hood lining... |
Is there a paint that i can use to paint the hood lining? Spraypack or brush? |
Author: | Angusdog [ Thu Jun 09, 2005 6:53 pm ] |
I had good results painting my seats with that spray-on vinyl paint, although haven't used them yet so don't know how well they'll wear. This wouldn't be an issue with a headlining (except from feet when you're um 'busy'), but make sure it's not gloss paint you use. I have also bought 10 metres of black microsuede and an industrial sewing machine and plan to make new headlinings for my minis, when I get some time... |
Author: | 71_mini_k [ Fri Jun 10, 2005 1:23 pm ] |
I reprayed my sunvisors with VHT vinyl spray paint and it worked a treat. Had to do multiple coats though ![]() |
Author: | Mini Mad [ Fri Jun 10, 2005 1:33 pm ] |
i'd be too scared to spray some seats and then sit on them ![]() |
Author: | PEDDRO [ Fri Jun 10, 2005 2:41 pm ] |
The VHT vinyl spray works fine. I had to redo my hoodlining due to the bad job the knucklehead that owned my mini prior to me did. Have a couple of cans on hand though....running out mid-paint makes it look CRAP! Hence, you will have to do it again. |
Author: | Harley [ Fri Jun 10, 2005 3:42 pm ] |
Hood lining? Is that head lining, bonnet lining, boot lining or something else? Just want to be sure. |
Author: | drmini in aust [ Fri Jun 10, 2005 4:11 pm ] |
Um... roof lining I think... ![]() |
Author: | 64mini [ Fri Jun 10, 2005 5:19 pm ] |
oops.....roof lining...... |
Author: | aussie [ Fri Jun 10, 2005 6:17 pm ] |
yer, i was like...im missing something here..hood lining ![]() |
Author: | Namibian CAMEL [ Fri Jun 10, 2005 6:35 pm ] |
Greetings fellow Tasmanian ok so i have nothing to offer for this thread, but seeing as you are here, well im in your town this weekend might see you about ![]() ![]() ![]() if not ill see you around ![]() |
Author: | 64mini [ Fri Jun 10, 2005 7:02 pm ] |
when you comming over? |
Author: | Namibian CAMEL [ Fri Jun 10, 2005 7:07 pm ] |
62mini wrote: when you comming over?
Im here right now ![]() and probably will stay till at least late sunday, or maybe mondaym the holiday ![]() |
Author: | 64mini [ Fri Jun 10, 2005 7:11 pm ] |
want to meet up sun or mon.........my place....or down town...talk mini |
Author: | Namibian CAMEL [ Fri Jun 10, 2005 7:15 pm ] |
im not doing anything else, so yep, hopefully i can find some sleep and look in respectable condition ![]() ![]() ![]() maybe you can or ill send a PM, if you like. you can fix my mini for me ![]() ![]() |
