RE-13 cams- rocker clearance https://www.ausmini.com/forums/viewtopic.php?f=5&t=8097 |
Author: | drmini in aust [ Tue Jun 14, 2005 10:38 pm ] |
Post subject: | RE-13 cams- rocker clearance |
Hey guys, On RE-13 cams, Play around with the rocker clearances a little. I was running .020" (recommended for my 1.5 rockers) and found it goes harder when set to .018". ![]() If you are running std rockers with this cam, I'd try reducing it from .018" to .016". ![]() Don't go much less though..... it could get all cammy and piggy at low speed. ![]() And you might burn valves... <edited> for clarity. |
Author: | gafmo [ Tue Jun 14, 2005 11:05 pm ] |
O'w come on... I'm now running .019 with the standard rockers on Morris on crappy fuel while its pinging it head off ![]() Bling time again for the cover again... What gap for the 1.2 rockers Dr ![]() ![]() |
Author: | minster [ Tue Jun 14, 2005 11:07 pm ] |
Post subject: | . |
Do you have to adjust your rockers often? I have a 1100s engine with a mild cam of unknow origin what gap range should I use? What would hp do you think your engine is putting out these days Kevin? |
Author: | drmini in aust [ Tue Jun 14, 2005 11:10 pm ] |
gafmo wrote: O'w come on... I'm now running .019 with the standard rockers on Morris on crappy fuel while its pinging it head off
![]() Bling time again for the cover again... What gap for the 1.2 rockers Dr ![]() ![]() Read my post above... I said try .016". ![]() |
Author: | drmini in aust [ Tue Jun 14, 2005 11:14 pm ] |
Post subject: | Re: . |
minster wrote: Do you have to adjust your rockers often? No. I check `em every 5000 miles or so.
I have a 1100s engine with a mild cam of unknow origin what gap range should I use? I'd use .015" if you don't know what cam it is. What would hp do you think your engine is putting out these days Kevin? GR reckons ~120 (at crank) probably. |
Author: | minster [ Tue Jun 14, 2005 11:18 pm ] |
Post subject: | . |
Thats impressive stuff. A lot of people aim for that with superchargers on 1275's. What is the power range like with the RE-13 cam I know people have mentioned it before but does it produce a peaky engine? How is your clutch and gearbox standing up to the power? |
Author: | drmini in aust [ Wed Jun 15, 2005 7:13 am ] |
Power hits at 2700 with 1.5 rockers on it, it spins freely to 8000, but I don't run that high any more- I've seen too many motors bust things over 8K. So I limit this one to 7500. It's not cammy but does get a second wind from 5500-6000 up, with these rockers. GR says standard rockers are better on a road car- give more torque up to 6000. I can potter around at 2000 or less and it doesn't snatch, it's way more tractable than the Camtech VP3 I used to run. Considering it's got a 45DHLA carb and 36mm chokes I think it's pretty good. Gearbox- nothing busted yet! But I overhaul it whenever motor's off. Last motor lasted 45,000 hard miles until I seized a (forged) Mahle piston at Wakefield Pk... Clutch is an orange dot, standard B&B drive plate, with lightened flywheel & backplate- no problems yet. |
Author: | Mini Mad [ Wed Jun 15, 2005 8:39 am ] |
gafmo wrote: Don't tel Josh
![]() Toooo late ![]() ![]() |
Author: | Lillee [ Wed Jun 15, 2005 9:33 am ] |
Here's an interesting article: http://www.minimania.com/ArticleV.cfm?D ... r&CarType= They set the exhaust and inlet clearances differently... |
Author: | minster [ Wed Jun 15, 2005 7:29 pm ] |
Post subject: | . |
Sounds very impressive I can see why so many people out there have drmini spec motors. So how is it on fuel do you have any idea of what mileage it would return? |
Author: | drmini in aust [ Wed Jun 15, 2005 7:56 pm ] |
No idea really. I don't do many miles, so "dus'n matter" as Cont the Fruiterer would say. ![]() It's OK in traffic, doesn't foul plugs or anything. ![]() |
Author: | drmini in aust [ Sat Jun 18, 2005 5:38 pm ] |
68Delux wrote: Here's an interesting article:
http://www.minimania.com/ArticleV.cfm?D ... r&CarType= They set the exhaust and inlet clearances differently... Yeah that was specific to Metro cams though, as they idled like crap. No harm in playing about a bit with ODD clearances- but if you do, exhausts want to be looser than the inlets (when set cold) as they get hotter and expand more. |
