Twin 1 1/4 su needle recommendation. 1098 engine https://www.ausmini.com/forums/viewtopic.php?f=5&t=81248 |
Author: | Sean1098 [ Fri Apr 26, 2013 11:01 pm ] |
Post subject: | Twin 1 1/4 su needle recommendation. 1098 engine |
Hey guys, Just wondering as a base whether a pair of m needles on a standard 1098 with maniflow free flow extractors and k&n filters will do or would they tend to run lean? A dyno tune will follow but just want a starting point pre blue slip. |
Author: | drmini in aust [ Sat Apr 27, 2013 1:36 pm ] |
M needles generally work fine on a 1098 with twin HS2s and sports filters. If you need richer, try AH2. |
Author: | Sean1098 [ Sat Apr 27, 2013 9:30 pm ] |
drmini in aust wrote: M needles generally work fine on a 1098 with twin HS2s and sports filters.
If you need richer, try AH2. Perfect, thanks mate. I've got an m needle in one and an ah2 in the other. Don't know what the previous owner was up to. I'll source a second 'm' and throw it back together. Red springs okay with this set up? |
Author: | drmini in aust [ Sat Apr 27, 2013 10:08 pm ] |
Yes. |
