It is currently Tue Jul 08, 2025 5:51 pm
 Post subject: Ford FE Rod Bolts
PostPosted: Fri Oct 04, 2013 6:42 pm
I know that some people use the ARP Ford FE 3/8"rod bolts in S conrods, but are any modifications required?
I have heard of people using big block Chev rod bolts, but I believe that the knurled section on the bolt has to be machined and/or the rod bolt holes reamed to suit.
I have been offered a set of Ford ARP bolts at the right price, so curious to know what is required.
 Post subject: Re: Ford FE Rod Bolts
PostPosted: Fri Oct 04, 2013 7:21 pm
Yes I have used the `ARP' FE bolts a lot over the years, I used their BB Chev ones once 10 years ago but those did take serious machining.
There is a slight knurl band just under the head of the FE bolt, I just hold the bolt's thread gently in the lathe & polish that off a bit with a file + 180 paper. No machining is required.
If the S conrods have seen a lot of use you don't need to remove the knurl.
PostPosted: Fri Oct 04, 2013 7:31 pm
Thanks Doc, that was what I was hoping....the existing ARP bolts in my rods are a bit loose so the Ford bolts hopefully will sort this.
Thanks for the speedy response!
Greg
PostPosted: Sat Oct 05, 2013 8:38 am
And one set of ARP's is good enough for two mini's! (or two engine rebuilds) LOL
PostPosted: Sat Oct 05, 2013 2:34 pm
Also (with 16 bolts) it's only 1/2-2/3 the price of a set of 8 ARP Cooper S bolts. Material spec is the same.
